    Dialog Question
    19 Posts 0 Posters 1.9k Views
      On 12/01/2011 at 19:43, xxxxxxxx wrote:
      Cinema 4D Version:   12
      okay.. so if you go in to c4d add a sky object.. not a blank sky object, the AR sky object... then click on the BASIC tab and then click LOAD PRESET,  how can I create that type of dialog box?  The one that shows all of the sky presets as images?  How can I accomplish this type of dialog?
      ~Shawn
        On 12/01/2011 at 22:43, xxxxxxxx wrote:
        Not sure if you can exactly mimic it but you can set up each preset from an image as a BitmapButton.  A basic way to do this is in CreateLayout() (or method called from there) using something like this:
        // BitMap Button
        BaseContainer    thumb_bc;
        thumb_bc.SetLong(DESC_CUSTOMGUI,                    CUSTOMGUI_BITMAPBUTTON);
        thumb_bc.SetLong(BITMAPBUTTON_BORDER,                BORDER_IN);
        thumb_bc.SetBool(BITMAPBUTTON_BUTTON,                TRUE);
        thumb_bc.SetBool(BITMAPBUTTON_TOGGLE,                FALSE);
        thumb_bc.SetBool(BITMAPBUTTON_DRAWPOPUPBUTTON,        FALSE);
        BitmapButtonCustomGui*    bmbutton =    (BitmapButtonCustomGui* )AddCustomGui(id,CUSTOMGUI_BITMAPBUTTON,String(),BFH_CENTER|BFV_CENTER,SizePix(64L),SizePix(64L),thumb_bc);
        if (!bmbutton) return FALSE;
        // bm = BaseBitmap* to loaded image
        bmbutton->SetImage(bm, TRUE, FALSE);
          On 13/01/2011 at 03:18, xxxxxxxx wrote:
          Yes, that's exactly what I do in my sIBL Loader plugin, which shows a variable number of presets depending on which collection of presets the user has chosen. I add the required number of BitmapButton elements to a ListView so the display of presets can be scrolled within the dialog if necessary.
            On 14/01/2011 at 06:40, xxxxxxxx wrote:
            The AR Sky is using the BrowserLibraryPopup function to display the popup. This invlolves some knowledge about Content Browser programming though.
              On 14/01/2011 at 06:57, xxxxxxxx wrote:
              Thanks Matthias,  I will check out the SDK for that function when I get home.  Is there literature on Content Browser programming at all anywhere?
              ~Shawn
              EDIT:   Nevermind.  I got around my work computer's block for downloading the SDK here at work by downloading it on my phone and pulling it off of there.  I can now look through the Browser related functions.  Thanks again Matthias.  🙂
              ~Shawn
                On 14/01/2011 at 12:52, xxxxxxxx wrote:
                Okay so I am trying to use : BrowserLibraryPopup
                but am running in to some trouble.   I  saw an earlier post by Matthias HERE.
                Here is the code I am messing with so far.
                //MESSAGE
                Bool PlanetXObject::Message(GeListNode *node, LONG type, void *t_data){
                  BaseContainer state;
                   GetInputState(BFM_INPUT_MOUSE, 0/*BFM_INPUT_MOUSELEFT*/, state);
                   LONG mx = state.GetReal(BFM_INPUT_X);
                   LONG my = state.GetReal(BFM_INPUT_Y);
                  switch (type){
                      case MSG_DESCRIPTION_COMMAND:
                          BrowserLibraryPopup(mx, my, 200, 200, MYWINDOWID, CBPluginTypeObjectPreset, NULL, BPop);
                my problem is,  that Bpop  is supposed to be a
                BrowserPopupCallback_<_h4_>_
                and I have no idea how to use that.  Could someone explain that better to me?
                ~Shawn
                  On 14/01/2011 at 17:11, xxxxxxxx wrote:
                  So if I want to create a Browser Plugin ,  Do I have my class inherit from
                  **SDKBrowser** or should it inherit from **SDKBrowserPluginInterfaceInfo ?
                  Shawn
                    On 17/01/2011 at 05:41, xxxxxxxx wrote:
                    okay so I am able to get the dialog to open like this.
                          case MSG_DESCRIPTION_COMMAND:{
                              DescriptionCommand *dc = (DescriptionCommand* ) t_data;
                              if(!dc)return FALSE;
                              //LOAD PRESET
                              if (dc->id==(DescID)PLANETX_SURFACE_LOAD_PRESET)
                                  BrowserLibraryPopup(mx, my, width, height,ID_SURFACEPRESETS_WINDOW, CBPluginTypeDefaults, NULL, NULL);
                              //SAVE PRESET
                              if (dc->id==(DescID)PLANETX_SURFACE_SAVE_PRESET)
                                  GePrint("Save Preset");
                    Now my question is, how do I get a specific .lib4d file to load in to the dialog ?
                    ~Shawn
                      On 17/01/2011 at 13:45, xxxxxxxx wrote:
                      Anyone know anything about calling in files from the content browser?  🙂
                      ~Shawn
                        On 18/01/2011 at 06:56, xxxxxxxx wrote:
                        In order to show your own presets you need to program your own content browser plugin. I will try to put an example together.
                          On 18/01/2011 at 09:42, xxxxxxxx wrote:
                          Thanks Matthias,   that would be extremely helpful.   I appreciate you taking the time to do it.
                          ~Shawn
                            On 25/01/2011 at 19:47, xxxxxxxx wrote:
                            Is a broswer plugin made with SDKBrowser or SDKBrowserPluginInterfaceInfo ?
                              On 26/01/2011 at 01:35, xxxxxxxx wrote:
                              The plugin is derived from SDKBrowserPluginInterfaceInfo and registered with SDKBrowser::RegisterBrowserPlugin().
                              I have never written a browser plugin myself so currently I can't tell you much about it. I am still waiting for an answer from our developers.
                                On 26/01/2011 at 03:13, xxxxxxxx wrote:
                                Thanks Matthias,
                                I'm gonna have a play with it to see if I can piece one together until you hear back from them.
                                ~Shawn
                                  On 30/01/2011 at 15:27, xxxxxxxx wrote:
                                  Okay so here is my first attempt at writing a browser plugin.
                                  Everything works except the registration function.  Does anyone see what I am doing wrong with the registration function for this plugin?
                                  I am using the class as the SDKBrowserPluginInterfaceInfo that is required in the registration.
                                  Here's the code:
                                  //BROWSER INTERFACE PLUGIN
                                  #include "c4d.h"
                                  #include "c4d_symbols.h"
                                  #include "lib_browser.h"
                                  //PLUGIN ID
                                  #define PXG_BROWSER_PLUGIN 1026577
                                  class PXGBrowserPlugin : public SDKBrowserPluginInterfaceInfo{
                                    virtual LONG GetPluginID(String* plugin_name);
                                    virtual Bool Identify(const SDKBrowserURL& url, UCHAR* probe, LONG size, ULONG flags);
                                    virtual String GetTypeName(const SDKBrowserContentNodeRef node, const SDKBrowserURL* url, LONG mode);
                                   // virtual String* GetTypeNames(LONG mode, LONG* no_strings);
                                    virtual SDKBrowserPreviewData* OpenPreviewBitmap(BaseThread* thread, const SDKBrowserContentNodeRef node, const SDKBrowserURL* url, SDKBrowserPreviewInfo* info);
                                    virtual void ClosePreviewBitmap(SDKBrowserPreviewData* data);
                                    virtual BaseBitmap* GetPreviewBitmap(SDKBrowserPreviewData* data, LONG w, LONG h, LONG quality);
                                    virtual SDKBrowserIcon* GetIcon(const SDKBrowserURL& url, LONG pref_wh);
                                    virtual SubDialog* OpenPreviewDialog(SDKBrowserContentNodeRef node, LONG tab_id);
                                    virtual LONG ClosePreviewDialog(SDKBrowserContentNodeRef node, SubDialog* s);
                                    virtual Bool Open(SDKBrowserContentNodeRef node, const SDKBrowserURL* url, LONG flags);
                                  LONG PXGBrowserPlugin::GetPluginID(String* plugin_name){
                                    return NULL;
                                  Bool PXGBrowserPlugin::Identify(const SDKBrowserURL& url, UCHAR* probe, LONG size, ULONG flags){
                                  String PXGBrowserPlugin::GetTypeName(const SDKBrowserContentNodeRef node, const SDKBrowserURL* url, LONG mode){
                                    String test = "Test";
                                    return test;
                                  String* PXGBrowserPlugin::GetTypeNames(LONG mode, LONG* no_strings){
                                    String *test = "Test";
                                    return test;
                                  SDKBrowserPreviewData* PXGBrowserPlugin::OpenPreviewBitmap(BaseThread* thread, const SDKBrowserContentNodeRef node, const SDKBrowserURL* url, SDKBrowserPreviewInfo* info){
                                  void PXGBrowserPlugin::ClosePreviewBitmap(SDKBrowserPreviewData* data){
                                  BaseBitmap* PXGBrowserPlugin::GetPreviewBitmap(SDKBrowserPreviewData* data, LONG w, LONG h, LONG quality){
                                    AutoAlloc<BaseBitmap> bmap;
                                    return bmap;
                                  SDKBrowserIcon* PXGBrowserPlugin::GetIcon(const SDKBrowserURL& url, LONG pref_wh){
                                    SDKBrowserIcon *ico;
                                    return ico;
                                  SubDialog* PXGBrowserPlugin::OpenPreviewDialog(SDKBrowserContentNodeRef node, LONG tab_id){
                                    SubDialog* sd;
                                    return sd;
                                  LONG PXGBrowserPlugin::ClosePreviewDialog(SDKBrowserContentNodeRef node, SubDialog* s){
                                    return NULL;
                                  Bool PXGBrowserPlugin::Open(SDKBrowserContentNodeRef node, const SDKBrowserURL* url, LONG flags){
                                  Bool RegisterPXGBrowserPlugin(void){
                                    SDKBrowser *browser;
                                    return browser->RegisterBrowserPlugin(PXGBrowserPlugin, 0);
                                    On 31/01/2011 at 02:44, xxxxxxxx wrote:
                                    RegisterBrowserPlugin is a static method. You call it like this:
                                    EDIT: wrong code
                                      On 31/01/2011 at 03:11, xxxxxxxx wrote:
                                      Thanks matthias.   I still get this error:
                                      1>pxgbrowserplugin.cpp
                                      1>c:\program files\maxon\cinema 4d r12 demo\plugins\planet x generator 2.0\source\object\pxgbrowserplugin.cpp(86) : error C2275: 'PXGBrowserPlugin' : illegal use of this type as an expression
                                      Am I not allowed to use the class for the first argument for RegisterBrowserPlugin()?
                                      ~Shawn
                                        On 31/01/2011 at 03:20, xxxxxxxx wrote:
                                        Sorry I had an error in my code. You have to pass the allocted class.
                                          return SDKBrowser::RegisterBrowserPlugin(gNew PXGBrowserPlugin, 0);
                                          On 31/01/2011 at 03:36, xxxxxxxx wrote:
                                          Thanks Matthias.  It works now.  Just have to make sure I override all methods because it's abstract.  🙂
                                          LOL
                                          ~Shawn
