Python plugins.CommandData.GetSubContainer
On 07/01/2011 at 20:22, xxxxxxxx wrote:
Cinema 4D Version:
Language(s) : PYTHON ;---------
Hi,I have been trying create a submenu, but the exemple in the documentation doesnt work :
import c4d PLUGIN_ID = 1019277 class SubMenuTest(c4d.plugins.CommandData) : def GetSubContainer(self, doc, submenu) : bc = c4d.BaseContainer() bc.SetString(1, "Submenu Test") bc.SetString(1000, "First Entry") submenu.InsData(0,bc) return True if __name__ == "__main__": c4d.plugins.RegisterCommandPlugin(PLUGIN_ID, "Test de sous menu", 0, None, '-', SubMenuTest())What's wrong ?
Thanks and cheers.
olid
On 14/01/2011 at 03:11, xxxxxxxx wrote:
I can confirm this. I will forward this to the developers.
Matthias -
On 14/01/2011 at 03:30, xxxxxxxx wrote:
Submenus are currently not supported in Python. The documentation will change accordingly.
Matthias -
On 16/01/2011 at 00:21, xxxxxxxx wrote:
OK,
thx Matthias -
On 06/01/2014 at 18:09, xxxxxxxx wrote:
Is this still the case? I can't get submenus to work, but The 15.057 documentation definitely mentions them: [URL-REMOVED]#c4d.plugins.CommandData
On 07/01/2014 at 07:21, xxxxxxxx wrote:
GetSubContainer() is called when the Plugin Icon is docked in the interface of Cinema 4D and it is
clicked from there. The same limitation applies to GetSubContainer() of C++ plugins.Best,
-Niklas
