    Python: CallCommand?
    3 Posts 0 Posters 255 Views
      On 05/01/2011 at 06:14, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Platform:      Mac OSX  ;
      Language(s) :       PYTHON  ;
      I've seen various chucks of code with
      CallCommand(xxxx)
      ie
      c4d.CallCommand(1018791)#Fracture Object
      Fracture=doc.GetActiveObject()
      Is there a index of commands
      or more documentation on this pls?
        On 05/01/2011 at 06:32, xxxxxxxx wrote:
        If you select a command in Windows/Layout/Command Manager you can see the id in the bottom of the window.
        Otherwise in the same menu you can call "Script Log" and after all the command will appear in the Script log's window.
          On 05/01/2011 at 06:54, xxxxxxxx wrote:
          thanks for the pointer
