    HTML Viewer [SOLVED]
    Scheduled Pinned Locked Moved ResEdit
    5 Posts 0 Posters 2.4k Views
      On 03/01/2011 at 09:45, xxxxxxxx wrote:
      ResEdit Version:   R8
      Hi guys, just a tiny question:
      With ResEdit one can create "C4D Field" (Is it called so ?).
      One can choose a type called "HTML Viewer". But nowhere is described how to initialise the field.
      Does anyone know about it ?
      Thanks in advance, lg nux
        On 04/01/2011 at 00:29, xxxxxxxx wrote:
        Hello nux,
        In the Cinema4DR12SDK  you will find HTMLViewerCustomGui, maybe that helps. 😉
          On 04/01/2011 at 01:23, xxxxxxxx wrote:
          The Functions from the C++ SDK for the HTML Viewer don't work in COFFEE 😞
          Or do I use them wrong ?
          There is no ID variable in the Function SetUrl(), so i Just "added" it as it is in all other Functions for COFFEE for Dialogs. 😂
          This is my Init() Function of the Dialog:
          Dialog::Init() {
            var file = GeGetRootFilename();
            file->RemoveLast();
            file->AddLast(PATH);
            var url = FilenameToURL(file);
            SetURL(USR_HTML,file,URL_ENCODING_UTF16);
            return true;
            On 04/01/2011 at 08:33, xxxxxxxx wrote:
            COFFEE doesn´t support it.
              On 05/01/2011 at 06:07, xxxxxxxx wrote:
              Oh man .. -.-'
              So it's going to be time to learn C++ ..
              Thanks Katachi,
              greets, nux
