    python plugins ObjectData how can use the doc ?
    7 Posts 0 Posters 627 Views
      On 03/01/2011 at 02:05, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Language(s) :       PYTHON  ;
      Hi everyone this my first post i try use in plugins.ObjectData i want take the doc becuase i want take the time frame in this example  `` i know this dosen't work correct ``class MyMain(plugins.ObjectData) :
       def GetVirtualObjects(self, op, hh) :
         **doc=documents.GetActiveDocument()** # <- maybe need change this ? Time=doc.GetTime() Frame=Time.GetFrame(doc.GetFps()) print Frame if Frame==0:return c4d.Ocube ``   if Frame==10:return c4d.Ocone
      `   if Frame==20:r:return c4d.OSphere
      return None
      the problem is here ``doc=documents.GetActiveDocument() dosen't work correct in render
        i think i need something like this to use **ObjectData. AddToExecution( _self_ , _op_ , _list_ ) ObjectData.Execute`( self , op , doc , bt , priority , flags )**
      here i have doc 🙂
      but i don't know how to use this
      any idea ?
      Thank you
        On 03/01/2011 at 04:05, xxxxxxxx wrote:
        Hi and Welcome to PluginCafe.com. Please try this:
        doc=op.GetDocument()
        Cheers, Sebastian
          On 03/01/2011 at 04:28, xxxxxxxx wrote:
          Thank you Very Much Sebastian now understand what i did wrong
          doc=op.GetDocument()  ->  so this Returns the document where the object is stored in .
          and work fine now  !
          Thank you again !!!!
            On 03/01/2011 at 04:38, xxxxxxxx wrote:
            Just want to add that GetActiveDocument returns only the opened editable document. The renderer, except viewport rendering, uses a clone of this document. This is why GetActiveDocument will return the wrong document during rendering.
              On 03/01/2011 at 05:03, xxxxxxxx wrote:
              Hi just i want to ask something i found now
              whe i use
              doc1=documents.GetActiveDocument()
                doc2=op.GetDocument()
                print doc1.GetFps()
                print doc2.GetFps()
              the doc1 work fine but if i use doc2 like op.GetDocument() say error
              i do something wrong ?
              i use in
              def Init(self, op) :
               because i want to install my vaules and one is c4d.BaseTime
                On 03/01/2011 at 15:52, xxxxxxxx wrote:
                In Init(..) the object is not in the document yet.
                obj=c4d.BaseObject(YOUR_PLUGIN_ID) #internal call of the constructor and Init(..) afterwards
                doc.InsertObject(obj) #here op is connected with the doc
                  On 04/01/2011 at 01:55, xxxxxxxx wrote:
                  ok thank you very much for clear this 😉
