    ObjectPlugin child draw
    8 Posts 0 Posters 681 Views
      On 17/12/2010 at 02:38, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      Hi all !
      I'm working on a little object plugin, the issue is that whatever object I put as a child of it, the child isn't visible anymore.
      I taught it was a redraw problem, but none of the messages, events, or drawview commands helped me.
      IMO it may come from the hierarchy that has to be updated... But how  ?
      If you have any idea ...
      Mike
        On 17/12/2010 at 03:32, xxxxxxxx wrote:
        Not visible in the Editor or in general ?
        What function did you use to insert the object ?
          On 17/12/2010 at 04:11, xxxxxxxx wrote:
          Not visible in the viewport only.
          I simply drag and drop an object (a cube as example) as a child of my plugin object. I can see the bounding box in the viewport and I can transform it but the object itself is not visible.
          Mike
            On 18/12/2010 at 18:54, xxxxxxxx wrote:
            What are you doing in GetVirtualObject()?
              On 18/12/2010 at 19:58, xxxxxxxx wrote:
              My thoughts exactly.  If there are no children, pass nothing back (or whatever is default).  If there are and nothing is being changed, pass the hierarchy as is (typically the result of GetAndCheckHierarchyClone() for instance).
                On 19/12/2010 at 02:52, xxxxxxxx wrote:
                Hi both !
                Thanks for helping.
                c4dJack :
                Here is my GetVirtualObject() dirty check for now.
                BaseObject    *cd=NULL,*orig=op->GetDown();
                op->NewDependenceList();
                Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTY_DATA)||op->IsDirty(DIRTY_CACHE);
                for (cd=orig; cd; cd=cd->GetNext())
                      op->AddDependence(hh,cd);
                if (!dirty) dirty = !op->CompareDependenceList();
                op->TouchDependenceList();
                if (!dirty) return op->GetCache(hh);
                if (dirty)
                  Main code
                kuroyume
                ok it seems like it is what i need but I can't get it work. Do you mean :
                If there are no children, pass nothing back (or whatever is default) :
                if (!op->GetDown()) {default code};
                if (op->GetDown())
                if (!dirty) return op->GetAndCheckHierarchyClone();
                Mike
                  On 19/12/2010 at 12:30, xxxxxxxx wrote:
                  The way you are doing it (using a dependence list), the Triangulate example in the cinema4dsdk plugins should be the best to follow:
                  BaseObject *TriangulateData::GetVirtualObjects(BaseObject *op, HierarchyHelp *hh)
                    if (!op->GetDown()) return NULL;  // No children to work on, return nothing
                    LineObject        *contour=NULL;
                    PolygonObject *pp=NULL;
                    Bool                    dirty=FALSE;
                    Matrix                ml;
                    contour=PrepareSingleSpline(op,op->GetDown(),&ml,hh,&dirty);
                    if (!dirty) dirty = op->CheckCache(hh);
                    if (!dirty) dirty = op->IsDirty(DIRTYFLAGS_DATA);
                    if (!dirty) return op->GetCache(hh); // No changes, return the cache (GetAndCheckHierarchyClone() is the simpler route when not using dependence lists)
                    if (!contour) return NULL;
                    pp = contour->Triangulate(0.0,hh->GetThread());
                    if (!pp) return NULL;
                    pp->SetPhong(TRUE,FALSE,0.0);
                    Transform(pp,ml);
                    pp->SetName(op->GetName());
                    if (hh->GetBuildFlags()&BUILDFLAGS_ISOPARM)
                        pp->SetIsoparm((LineObject* )contour->GetClone(COPYFLAGS_NO_HIERARCHY,NULL));
                        Transform(pp->GetIsoparm(),ml);
                    return pp;
                    On 22/12/2010 at 06:58, xxxxxxxx wrote:
                    Thanks a lot ! I think I understand how dirty works much better now.
                    Mike
