    Access object attributes with Python
    3 Posts 0 Posters 309 Views
      On 14/12/2010 at 08:16, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Language(s) :       PYTHON  ;
      Hi all,
      just a simple question: how can I access an object attribute in Python? In Coffee it was something like object#ATTRIBUTE_ID, with the id automatically written by a drag and drop from the attribute's field. Is there something similar in Python?
      Riccardo
        On 14/12/2010 at 08:25, xxxxxxxx wrote:
        Hello cosmodrome,
        You can also drag&drop the attribute in to the python-console.
        To access an example: obj[c4d.PRIM_CUBE_SUBX]=10
          On 14/12/2010 at 08:58, xxxxxxxx wrote:
          Thank you for your answer.
          In fact my problem was more general, because in Coffee the variable "op" is a reference to the object the Coffee tag is applied, whereas in Python - as I just discovered - op is a reference to the tag itself, so I had to write something like:
          obj = op.GetObject()
          obj[c4d.ATTRIBUTE_ID] = 10
          and that way it works 🙂
          Riccardo
