    adding TP dataChannel
    4 Posts 0 Posters 403 Views
      On 12/12/2010 at 09:20, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Language(s) :       PYTHON  ;
      Hello everyone,
      i would like to add new data channels to my tp particles. I'm not sure how to do it, and perhaps someone can help me.
      i add a datachannel via:
       tp.AddDataChannel(0,"mytestchannel")
      the api says that the first int defines the type of data i save in my channel. Unfortunatly i couldn't find a description of the Datatypes available. Can someone give me a hint on it?
      i just tried to add soem integer data via:
      tp.SetPData(pid,0,12)
      but it throws a TypeError: The data channel is not accessible:'145286240'
      i guess 0 is not for integer types 😕
      My first goal would be to store simple datatypes in my channels but i'd like to achieve even more complex datatypes (perhaps self defined classes?)
      However, i would be really glad if someone could give me a hint or perhaps points me to a direction where i can learn more about datachannels and SetPData and GetPData.
      thanks,
      alf Laune
        On 12/12/2010 at 09:59, xxxxxxxx wrote:
        Hi, to create a custom integer channel check out:
        tp.AddDataChannel(c4d.DTYPE_LONG,"mytestchannel")
        Here is a small list of types which can be used as well:
        DTYPE_COLOR,
        DTYPE_TEXTURE,
        DTYPE_LONG,
        DTYPE_REAL,
        DTYPE_TIME,
        DTYPE_VECTOR,
        DTYPE_MATRIX,
        DTYPE_STRING,
        DTYPE_FILENAME,
        DTYPE_BOOL,
        DTYPE_NORMAL
        Cheers, Sebastian
          On 12/12/2010 at 11:52, xxxxxxxx wrote:
          Hi Sebastian,
          thank you for your answer. It works very well. Is there a possibility to add more complex types? Like Arrays for example or structs?
          thanks,
          alf
            On 12/12/2010 at 13:53, xxxxxxxx wrote:
            Unfortunately thats not possible. To check out which types can be set, just open the TP Settings Dialog.
            (Simulation->Thinking Particles->Thinking Particles Settings->Tab: Channels)
