    Tranfer Project from 11.5 to 12
    4 Posts 0 Posters 343 Views
      On 08/12/2010 at 02:25, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Dev. System: Visual C++ 2008 Express Edition.
      When compiling our Project we get some errors.
      Can anybody help us ??
      Here is the source:
      #include "c4d.h"
      class ButtonAData : public CommandData
                virtual Bool          Execute (BaseDocument *doc);
                virtual LONG          GetState(BaseDocument *doc);
                virtual Bool           RestoreLayout (void* secret);
                virtual void          Message (const BaseContainer& msg);
      LONG ButtonAData::GetState(BaseDocument *doc)
           return CMD_ENABLED;
      Bool ButtonAData::RestoreLayout (void* secret)
      void ButtonAData::Message (const BaseContainer& msg)
      void LoopThroughObjects(BaseObject *bobj, BaseObject *altD, BaseObject *altN, BaseDocument *bdoc, AliasTrans *T)
           while (bobj)
                BaseObject *obj=(BaseObject* )bobj->GetClone(COPYFLAGS_NO_HIERARCHY, T);
                bdoc->InsertObject(obj, altD, altN, FALSE);
                altN=obj;
                altD=NULL;
                bdoc->AddUndo(UNDOTYPE_NEW, obj);
                if (bobj->GetDown()) altD=obj;
                LoopThroughObjects(bobj->GetDown(), altD, NULL, bdoc, T);
                bobj=bobj->GetNext();
      Bool ButtonAData::Execute(BaseDocument *doc)
           LONG i;
           CHAR *Einer=NULL;
           String Inhalt="";
           BaseDocument* LoadScene=NULL;
           BaseMaterial *material, *cmat;
           StopAllThreads();
           AutoAlloc<BaseFile> SceneAPref;
           Filename Fname=Filename(GeGetPluginPath()+Filename("SceneRef.prf"));
           if (SceneAPref->Open(Fname, FILEOPEN_READ, FILEDIALOG_NONE))
                Einer = ( CHAR * )GeAlloc( sizeof (CHAR)*300);
                for (i=0; i<300; i++)
                     if (SceneAPref->ReadChar(Einer) && i>3) Inhalt+=String(Einer);
                GeFree(Einer);
                if (Inhalt!="")
                     Fname.SetString(Inhalt);
                     LoadScene=LoadDocument(Fname, SCENEFILTER_OBJECTS | SCENEFILTER_MATERIALS, NULL);
                     if (LoadScene)
                          AutoAlloc <AliasTrans> trans;
                          if (!trans || !trans->Init(LoadScene)) return FALSE;
                          doc->StartUndo();
                          material = LoadScene->GetFirstMaterial();
                          while (material)
                               cmat = (BaseMaterial* )material->GetClone(COPYFLAGS_0, trans);
                               doc->InsertMaterial(cmat, NULL, TRUE);
                               doc->AddUndo(UNDOTYPE_NEW, cmat);
                               material=material->GetNext();
                          doc->EndUndo();
                          doc->StartUndo();
                          LoopThroughObjects (LoadScene->GetFirstObject(), NULL, NULL, doc, trans);
                          doc->EndUndo();
                          EventAdd();
                          KillDocument(LoadScene);
                          LoadScene=NULL;
      #define ID_BUTA 1017169
      Bool RegisterButtonACommand(void)
           return RegisterCommandPlugin(ID_BUTA,"Scene Loader A",0,AutoBitmap("ButtonA.tif"),String("Scene Loader A"),gNew ButtonAData);
      We get these Results:
      1>c:\program files\maxon\cinema 4d r12\plugins\cinema4dsdk\source ool\buttona.cpp(11) : warning C4263: 'LONG ButtonAData::Message(const BaseContainer &,BaseContainer &)': Memberfunktion überschreibt keine virtuelle Memberfunktion einer Basisklasse
      1>c:\program files\maxon\cinema 4d r12\plugins\cinema4dsdk\source ool\buttona.cpp(12) : error C4264: 'Bool CommandData::Message(LONG,void * )': Keine Überschreibung für virtuelle Memberfunktion der Basis 'CommandData' verfügbar; die Funktion wird ausgeblendet
      1>        c:\.....\c4d_commanddata.h(47) : Siehe Deklaration von 'CommandData::Message'
      1>        c:\.....\c4d_commanddata.h(35) : Siehe Deklaration von 'CommandData'
      1>c:\.....\source ool\buttona.cpp(25) : error C2511: 'void ButtonAData::Message(const BaseContainer &)': Überladene Memberfunktion nicht in 'ButtonAData' gefunden
      1>        c:\.....\source ool\buttona.cpp(3) : Siehe Deklaration von 'ButtonAData'
      Thanks for any help
      Ronald
        On 08/12/2010 at 02:59, xxxxxxxx wrote:
        Please have a look at the declaration for CommandData::Message. Your declaration doesn't match the one of CommandData.
        It should be:
        virtual Bool Message(LONG type, void* data);
          On 08/12/2010 at 05:57, xxxxxxxx wrote:
          Thank you for your quick answer.
          I could not interpret your answer.
          Could you please be so kind and korrekt the line(s) in my Code.
          Thank 1000 times
            On 09/12/2010 at 02:21, xxxxxxxx wrote:
            Since you are not doing anything in CommandData::Message you simply can remove it from the class (declaration and defintion).
