    What I need for 32 Bit and 64 Bit
    2 Posts 0 Posters 205 Views
      On 07/12/2010 at 23:52, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      Language(s) :       PYTHON  ;
      Hey Guys,
      A little question:
      What must i care about, that my plug-in works in Cinema 4D 32 and 64 Bit? Or is it only necessary by libraries?
      ______
      An other question:
      I need a plugintyp witch start on program start of cinema 4d and is alltime activated. Also should have a gui-Layout.
      What is the right one?
      CommandPlugin, MessangerPlugin?...and how to script it, that its do not terminate after a few seconds.
        On 08/12/2010 at 04:57, xxxxxxxx wrote:
        Ok, I get it with MessagePlugin.
        But how can I also add a layout? Where should the function be called?
        €: I use now to registerplugins in one file with two different pluginids. Is there a better version out there?
        from c4d import gui, plugins, utils, bitmaps
        class MyDialog(gui.GeDialog) :
            check_RenderFullSize = None
          txt_Username = None
          txt_Password = None
          def CreateLayout(self) :
              etc...
        class Menu(plugins.CommandData) :
          dialog = None
          def Execute(self,doc) :
              if self.dialog is None:
                  self.dialog = MyDialog()
              return self.dialog.Open(dlgtype=True, pluginid=PLUGIN_ID, xpos=-1, ypos=-1, defaultw=180, defaulth=100)
          def RestoreLayout(self, sec_ref) :
              return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
        class GetInfo(plugins.MessageData) :
          def CoreMessage(self,id,bc) :
              if id==c4d.EVMSG_CHANGE: print("hey")
          PLUGIN_ID = XXXXXX
          c4d.plugins.RegisterCommandPlugin(PLUGIN_ID, "GetInfo", 0, None, "GetInfo", Menu())
          PLUGIN_ID = XXXXXXY
          c4d.plugins.RegisterMessagePlugin(PLUGIN_ID, "GetInfo", c4d.PLUGINFLAG_COMMAND_HOTKEY, GetInfo())
