    NET Client Crash
    4 Posts 0 Posters 369 Views
      On 28/11/2010 at 17:23, xxxxxxxx wrote:
      Cinema 4D Version:   R10-R12
      Now that I've internalized all my stock object, I am getting a NET Client crash when attempting to do a job using my plugin (Access Violation).  I was assured that multiprocessor threading and NET Render would be compatible.  There are no problems rendering (editor, external renderer) in Cinema 4D R10-12.  So this is strictly an issue between my plugin and NET Client.
      Could someone at Maxon please advise?  My last query has been five days unanswered and I resorted to spending two days internalizing 36 polygon objects.  You don't know anything about interactions between C++ SDK plugins and NET Render or what?  I'll thank you when I get a response.
        On 29/11/2010 at 06:13, xxxxxxxx wrote:
        I am sorry for the late reply. Please send a simplified plugin project to [email protected] showing the problem otherwise it's not possible for me to find a solution.
          On 29/11/2010 at 12:12, xxxxxxxx wrote:
          Not much I can do to simply the project.  It is ready-for-release and everything is very much interdependent (except for maybe the plugin tag which isn't where the problem resides).  It is still in Greebler.LoadStockLibrary() and the method that it calls for each shape object.  The code is supplied below.  Note that every single solitary memory allocation is checked and there are no error messages (I'm now also opening a MessageDialog() - still silent crash!).  Also note that there are no problems, issues, or crashes whatsoever in Cinema 4D using this code.
          // Greebler.LoadStockLibrary
          Bool Greebler::LoadStockLibrary()
            // Create Stock Shape Objects programmatically (because of C4D NET Client)
            if (!CreateStockObject("Cube", Cube_Extrude, Cube_ExtrudeCap, Cube_Bevel, Cube_BevelCap))                    return FALSE;
            if (!CreateStockObject("T", T_Extrude, T_ExtrudeCap, T_Bevel, T_BevelCap))                                    return FALSE;
            if (!CreateStockObject("L", L_Extrude, L_ExtrudeCap, L_Bevel, L_BevelCap))                                    return FALSE;
            if (!CreateStockObject("C", C_Extrude, C_ExtrudeCap, C_Bevel, C_BevelCap))                                    return FALSE;
            if (!CreateStockObject("H", H_Extrude, H_ExtrudeCap, H_Bevel, H_BevelCap))                                    return FALSE;
            if (!CreateStockObject("D", D_Extrude, D_ExtrudeCap, D_Bevel, D_BevelCap))                                    return FALSE;
            if (!CreateStockObject("Box", Box_Extrude, Box_ExtrudeCap, Box_Bevel, Box_BevelCap))                        return FALSE;
            if (!CreateStockObject("CubeCC", CubeCC_Extrude, CubeCC_ExtrudeCap, CubeCC_Bevel, CubeCC_BevelCap))            return FALSE;
            if (!CreateStockObject("OblongOctagon", OblOct_Extrude, OblOct_ExtrudeCap, OblOct_Bevel, OblOct_BevelCap))    return FALSE;
          // Greebler.CreateStockObject
          Bool Greebler::CreateStockObject(const String& name, StockShapeDefs ssd_extrude, StockShapeDefs ssd_extcap, StockShapeDefs ssd_bevel, StockShapeDefs ssd_bevcap)
            // Create All Shape objects and tags
            AutoAlloc<PolygonObject>    extrude(ssd_extrude.numPoints, ssd_extrude.numPolygons);
            if (!extrude)                return ErrPrt("Greebler.Greebler.CreateStockObject.extrude");
            extrude->SetName("Extrude");
            AutoAlloc<PolygonObject>    extcap(ssd_extcap.numPoints, ssd_extcap.numPolygons);
            if (!extcap)                return ErrPrt("Greebler.Greebler.CreateStockObject.extcap");
            extcap->SetName("ExtrudeCap");
            AutoAlloc<PolygonObject>    bevel(ssd_bevel.numPoints, ssd_bevel.numPolygons);
            if (!bevel)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bevel");
            bevel->SetName("Bevel");
            AutoAlloc<PolygonObject>    bevcap(ssd_bevcap.numPoints, ssd_bevcap.numPolygons);
            if (!bevcap)                return ErrPrt("Greebler.Greebler.CreateStockObject.bevcap");
            bevcap->SetName("BevelCap");
            AutoAlloc<BaseObject>        nop(Onull);
            if (!nop)                    return ErrPrt("Greebler.Greebler.CreateStockObject.nop");
            nop->SetName(name);
            // - PolygonSelection and PointSelection tags
            // -- Extrude
            AutoAlloc<SelectionTag>        ext_po_top(Tpolygonselection);
            if (!ext_po_top)            return ErrPrt("Greebler.Greebler.CreateStockObject.ext_po_top");
            ext_po_top->SetName("Top");
            AutoAlloc<SelectionTag>        ext_po_sides(Tpolygonselection);
            if (!ext_po_sides)            return ErrPrt("Greebler.Greebler.CreateStockObject.ext_po_sides");
            ext_po_sides->SetName("Sides");
            AutoAlloc<SelectionTag>        ext_pt_top(Tpointselection);
            if (!ext_pt_top)            return ErrPrt("Greebler.Greebler.CreateStockObject.ext_pt_top");
            ext_pt_top->SetName("Top");
            // -- ExtrudeCap
            AutoAlloc<SelectionTag>        extc_po_top(Tpolygonselection);
            if (!extc_po_top)            return ErrPrt("Greebler.Greebler.CreateStockObject.extc_po_top");
            extc_po_top->SetName("Top");
            AutoAlloc<SelectionTag>        extc_po_sides(Tpolygonselection);
            if (!extc_po_sides)            return ErrPrt("Greebler.Greebler.CreateStockObject.extc_po_sides");
            extc_po_sides->SetName("Sides");
            AutoAlloc<SelectionTag>        extc_po_cap(Tpolygonselection);
            if (!extc_po_cap)            return ErrPrt("Greebler.Greebler.CreateStockObject.extc_po_cap");
            extc_po_cap->SetName("Cap");
            AutoAlloc<SelectionTag>        extc_pt_top(Tpointselection);
            if (!extc_pt_top)            return ErrPrt("Greebler.Greebler.CreateStockObject.extc_pt_top");
            extc_pt_top->SetName("Top");
            // -- Bevel
            AutoAlloc<SelectionTag>        bev_po_top(Tpolygonselection);
            if (!bev_po_top)            return ErrPrt("Greebler.Greebler.CreateStockObject.bev_po_top");
            bev_po_top->SetName("Top");
            AutoAlloc<SelectionTag>        bev_po_sides(Tpolygonselection);
            if (!bev_po_sides)            return ErrPrt("Greebler.Greebler.CreateStockObject.bev_po_sides");
            bev_po_sides->SetName("Sides");
            AutoAlloc<SelectionTag>        bev_po_bevel(Tpolygonselection);
            if (!bev_po_bevel)            return ErrPrt("Greebler.Greebler.CreateStockObject.bev_po_bevel");
            bev_po_bevel->SetName("Bevel");
            AutoAlloc<SelectionTag>        bev_pt_top(Tpointselection);
            if (!bev_pt_top)            return ErrPrt("Greebler.Greebler.CreateStockObject.bev_pt_top");
            bev_pt_top->SetName("Top");
            AutoAlloc<SelectionTag>        bev_pt_sides(Tpointselection);
            if (!bev_pt_sides)            return ErrPrt("Greebler.Greebler.CreateStockObject.bev_pt_sides");
            bev_pt_sides->SetName("Sides");
            // -- BevelCap
            AutoAlloc<SelectionTag>        bevc_po_top(Tpolygonselection);
            if (!bevc_po_top)            return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_po_top");
            bevc_po_top->SetName("Top");
            AutoAlloc<SelectionTag>        bevc_po_sides(Tpolygonselection);
            if (!bevc_po_sides)            return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_po_sides");
            bevc_po_sides->SetName("Sides");
            AutoAlloc<SelectionTag>        bevc_po_cap(Tpolygonselection);
            if (!bevc_po_cap)            return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_po_cap");
            bevc_po_cap->SetName("Cap");
            AutoAlloc<SelectionTag>        bevc_po_bevel(Tpolygonselection);
            if (!bevc_po_bevel)            return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_po_bevel");
            bevc_po_bevel->SetName("Bevel");
            AutoAlloc<SelectionTag>        bevc_pt_top(Tpointselection);
            if (!bevc_pt_top)            return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_pt_top");
            bevc_pt_top->SetName("Top");
            AutoAlloc<SelectionTag>        bevc_pt_sides(Tpointselection);
            if (!bevc_pt_sides)            return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_pt_sides");
            bevc_pt_sides->SetName("Sides");
            // Set up Points and Polygons
            // - Extrude
            LONG        i;
            Vector*        points =        extrude->GetPointW();
            if (!points)                return ErrPrt("Greebler.Greebler.CreateStockObject.extrude->GetPointW");
            CPolygon*    polys =            extrude->GetPolygonW();
            if (!polys)                    return ErrPrt("Greebler.Greebler.CreateStockObject.extrude->GetPolygonW");
            CopyMem(ssd_extrude.points, points, sizeof(Vector)*ssd_extrude.numPoints);
            for (i = 0L; i != ssd_extrude.numPolygons; ++i)
                polys[i].a =    ssd_extrude.polygons[i][0];
                polys[i].b =    ssd_extrude.polygons[i][1];
                polys[i].c =    ssd_extrude.polygons[i][2];
                polys[i].d =    ssd_extrude.polygons[i][3];
            // - Create UVWTag and set it up.
            if (!CreateUVs(extrude, polys, points, NULL, ssd_extrude.numPolygons, ssd_extrude.numPoints))    return ErrPrt("Greebler.Greebler.CreateStockObject.CreateUVs(extrude)");
            // - Extrude Cap
            points =                    extcap->GetPointW();
            if (!points)                return ErrPrt("Greebler.Greebler.CreateStockObject.extcap->GetPointW");
            polys =                        extcap->GetPolygonW();
            if (!polys)                    return ErrPrt("Greebler.Greebler.CreateStockObject.extcap->GetPolygonW");
            CopyMem(ssd_extcap.points, points, sizeof(Vector)*ssd_extcap.numPoints);
            for (i = 0L; i != ssd_extcap.numPolygons; ++i)
                polys[i].a =    ssd_extcap.polygons[i][0];
                polys[i].b =    ssd_extcap.polygons[i][1];
                polys[i].c =    ssd_extcap.polygons[i][2];
                polys[i].d =    ssd_extcap.polygons[i][3];
            if (!CreateUVs(extcap, polys, points, NULL, ssd_extcap.numPolygons, ssd_extcap.numPoints))    return ErrPrt("Greebler.Greebler.CreateStockObject.CreateUVs(extcap)");
            // - Bevel
            points =                    bevel->GetPointW();
            if (!points)                return ErrPrt("Greebler.Greebler.CreateStockObject.bevel->GetPointW");
            polys =                        bevel->GetPolygonW();
            if (!polys)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bevel->GetPolygonW");
            CopyMem(ssd_bevel.points, points, sizeof(Vector)*ssd_bevel.numPoints);
            for (i = 0L; i != ssd_bevel.numPolygons; ++i)
                polys[i].a =    ssd_bevel.polygons[i][0];
                polys[i].b =    ssd_bevel.polygons[i][1];
                polys[i].c =    ssd_bevel.polygons[i][2];
                polys[i].d =    ssd_bevel.polygons[i][3];
            if (!CreateUVs(bevel, polys, points, NULL, ssd_bevel.numPolygons, ssd_bevel.numPoints))    return ErrPrt("Greebler.Greebler.CreateStockObject.CreateUVs(bevel)");
            // - Bevel Cap
            points =                    bevcap->GetPointW();
            if (!points)                return ErrPrt("Greebler.Greebler.CreateStockObject.bevcap->GetPointW");
            polys =                        bevcap->GetPolygonW();
            if (!polys)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bevcap->GetPolygonW");
            CopyMem(ssd_bevcap.points, points, sizeof(Vector)*ssd_bevcap.numPoints);
            for (i = 0L; i != ssd_bevcap.numPolygons; ++i)
                polys[i].a =    ssd_bevcap.polygons[i][0];
                polys[i].b =    ssd_bevcap.polygons[i][1];
                polys[i].c =    ssd_bevcap.polygons[i][2];
                polys[i].d =    ssd_bevcap.polygons[i][3];
            if (!CreateUVs(bevcap, polys, points, NULL, ssd_bevcap.numPolygons, ssd_bevcap.numPoints))    return ErrPrt("Greebler.Greebler.CreateStockObject.CreateUVs(bevcap)");
            // Set up PolygonSelections and PointSelections
            // - Extrude
            BaseSelect*    bs =            ext_po_top->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.ext_po_top->GetBaseSelect");
            bs->FromArray(&(ssd_extrude.posel_top)[0], ssd_extrude.numPolygons);
            bs =                        ext_po_sides->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.ext_po_sides->GetBaseSelect");
            bs->FromArray(&(ssd_extrude.posel_sides)[0], ssd_extrude.numPolygons);
            bs =                        ext_pt_top->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.ext_pt_top->GetBaseSelect");
            bs->FromArray(&(ssd_extrude.ptsel_top)[0], ssd_extrude.numPoints);
            // - Extrude Cap
            bs =                        extc_po_top->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.extc_po_top->GetBaseSelect");
            bs->FromArray(&(ssd_extcap.posel_top)[0], ssd_extcap.numPolygons);
            bs =                        extc_po_sides->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.extc_po_sides->GetBaseSelect");
            bs->FromArray(&(ssd_extcap.posel_sides)[0], ssd_extcap.numPolygons);
            bs =                        extc_po_cap->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.extc_po_cap->GetBaseSelect");
            bs->FromArray(&(ssd_extcap.posel_cap)[0], ssd_extcap.numPolygons);
            bs =                        extc_pt_top->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.extc_pt_top->GetBaseSelect");
            bs->FromArray(&(ssd_extcap.ptsel_top)[0], ssd_extcap.numPoints);
            // - Bevel
            bs =                        bev_po_top->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bev_po_top->GetBaseSelect");
            bs->FromArray(&(ssd_bevel.posel_top)[0], ssd_bevel.numPolygons);
            bs =                        bev_po_sides->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bev_po_sides->GetBaseSelect");
            bs->FromArray(&(ssd_bevel.posel_sides)[0], ssd_bevel.numPolygons);
            bs =                        bev_po_bevel->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bev_po_bevel->GetBaseSelect");
            bs->FromArray(&(ssd_bevel.posel_bevel)[0], ssd_bevel.numPolygons);
            bs =                        bev_pt_top->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bev_pt_top->GetBaseSelect");
            bs->FromArray(&(ssd_bevel.ptsel_top)[0], ssd_bevel.numPoints);
            bs =                        bev_pt_sides->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bev_pt_sides->GetBaseSelect");
            bs->FromArray(&(ssd_bevel.ptsel_sides)[0], ssd_bevel.numPoints);
            // - Bevel Cap
            bs =                        bevc_po_top->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_po_top->GetBaseSelect");
            bs->FromArray(&(ssd_bevcap.posel_top)[0], ssd_bevcap.numPolygons);
            bs =                        bevc_po_sides->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_po_sides->GetBaseSelect");
            bs->FromArray(&(ssd_bevcap.posel_sides)[0], ssd_bevcap.numPolygons);
            bs =                        bevc_po_bevel->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_po_bevel->GetBaseSelect");
            bs->FromArray(&(ssd_bevcap.posel_bevel)[0], ssd_bevcap.numPolygons);
            bs =                        bevc_po_cap->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_po_cap->GetBaseSelect");
            bs->FromArray(&(ssd_bevcap.posel_cap)[0], ssd_bevcap.numPolygons);
            bs =                        bevc_pt_top->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_pt_top->GetBaseSelect");
            bs->FromArray(&(ssd_bevcap.ptsel_top)[0], ssd_bevcap.numPoints);
            bs =                        bevc_pt_sides->GetBaseSelect();
            if (!bs)                    return ErrPrt("Greebler.Greebler.CreateStockObject.bevc_pt_sides->GetBaseSelect");
            bs->FromArray(&(ssd_bevcap.ptsel_sides)[0], ssd_bevcap.numPoints);
            // Release all from AutoAlloc
            // - put tags on objects
            extrude->InsertTag(ext_pt_top.Release());
            extrude->InsertTag(ext_po_sides.Release());
            extrude->InsertTag(ext_po_top.Release());
            extcap->InsertTag(extc_pt_top.Release());
            extcap->InsertTag(extc_po_cap.Release());
            extcap->InsertTag(extc_po_sides.Release());
            extcap->InsertTag(extc_po_top.Release());
            bevel->InsertTag(bev_pt_sides.Release());
            bevel->InsertTag(bev_pt_top.Release());
            bevel->InsertTag(bev_po_bevel.Release());
            bevel->InsertTag(bev_po_sides.Release());
            bevel->InsertTag(bev_po_top.Release());
            bevcap->InsertTag(bevc_pt_sides.Release());
            bevcap->InsertTag(bevc_pt_top.Release());
            bevcap->InsertTag(bevc_po_bevel.Release());
            bevcap->InsertTag(bevc_po_cap.Release());
            bevcap->InsertTag(bevc_po_sides.Release());
            bevcap->InsertTag(bevc_po_top.Release());
            // - put objects under Null object
            bevcap->InsertUnderLast(nop);
            bevel->InsertUnderLast(nop);
            extcap->InsertUnderLast(nop);
            extrude->InsertUnderLast(nop);
            bevcap.Release();
            bevel.Release();
            extcap.Release();
            extrude.Release();
            // - and Append Null to AtomArray
            if (!array_stock->Append(nop.Release()))    return ErrPrt("Greebler.Greebler.CreateStockObject.array_stock.Append()");
          And the header with the static shape object definitions (partial) :
          // StockShapeDefs.h
          // Greebler Stock Shape Geometry definitions
          // V1.0.0 2010.11.26 Robert Templeton
          #ifndef _STOCKSHAPEDEFS_H_
          #define _STOCKSHAPEDEFS_H_
          // Somewhere to internally define stock shape object information
          struct StockShapeDefs
            LONG        numPoints;
            LONG        numPolygons;
            Vector        points[40];
            LONG        polygons[40][4];
            // Polygon Selections
            UCHAR        posel_top[40];
            UCHAR        posel_sides[40];
            UCHAR        posel_cap[40];
            UCHAR        posel_bevel[40];
            // Point Selections
            UCHAR        ptsel_top[40];
            UCHAR        ptsel_sides[40];
          // Cube
          static StockShapeDefs    Cube_Extrude =
            8L, 5L,
                Vector(-0.5,    0.0,    -0.5),
                Vector(-0.5,    0.0,    0.5),
                Vector(0.5,        0.0,    0.5),
                Vector(0.5,        0.0,    -0.5),
                0L
                {7,        4,    5,    6},
                {3,        7,    6,    2},
                {2,        6,    5,    1},
                {1,        5,    4,    0},
                {0,        4,    7,    3},
                0L
            // Polygon
            // - Top
            {1,0,0,0,0},
            // - Sides
            {0,1,1,1,1},
            // - Cap
            {0L},
            // - Bevel
            {0L},
            // Point
            // - Top
            {0,0,0,0,1,1,1,1},
            // - Sides
            {0L}
          static StockShapeDefs    Cube_ExtrudeCap =
            8L, 6L,
                0L
                {7,        4,    5,    6},
                {2,        1,    0,    3},
                {3,        7,    6,    2},
                {2,        6,    5,    1},
                {1,        5,    4,    0},
                {0,        4,    7,    3},
                0L
            // Polygon
            // - Top
            {1,0,0,0,0,0},
            // - Sides
            {0,0,1,1,1,1},
            // - Cap
            {0,1,0,0,0,0},
            // - Bevel
            {0L},
            // Point
            // - Top
            {0,0,0,0,1,1,1,1},
            // - Sides
            {0L}
          static StockShapeDefs    Cube_Bevel =
            12L, 9L,
                Vector(0.0,        0.0,    0.0),
                0L
                {11,    8,    9,    10},
                {3,        7,    6,    2},
                {2,        6,    5,    1},
                {1,        5,    4,    0},
                {0,        4,    7,    3},
                {7,        11,    10,    6},
                {6,        10,    9,    5},
                {5,        9,    8,    4},
                {4,        8,    11,    7},
                0L
            // Polygon
            // - Top
            {1,0,0,0,0,0,0,0,0},
            // - Sides
            {0,1,1,1,1,0,0,0,0},
            // - Cap
            {0L},
            // - Bevel
            {0,0,0,0,0,1,1,1,1},
            // Point
            // - Top
            {0,0,0,0,0,0,0,0,1,1,1,1},
            // - Sides
            {0,0,0,0,1,1,1,1,0,0,0,0}
          static StockShapeDefs    Cube_BevelCap =
            12L, 10L,
                0L
                {11,    8,    9,    10},
                {2,        1,    0,    3},
                {3,        7,    6,    2},
                {2,        6,    5,    1},
                {1,        5,    4,    0},
                {0,        4,    7,    3},
                {7,        11,    10,    6},
                {6,        10,    9,    5},
                {5,        9,    8,    4},
                {4,        8,    11,    7},
                0L
            // Polygon
            // - Top
            {1,0,0,0,0,0,0,0,0,0},
            // - Sides
            {0,0,1,1,1,1,0,0,0,0},
            // - Cap
            {0,1,0,0,0,0,0,0,0,0},
            // - Bevel
            {0,0,0,0,0,0,1,1,1,1},
            // Point
            // - Top
            // - Sides
            On 29/11/2010 at 12:23, xxxxxxxx wrote:
            I will send you the entire project after some more tests.  I am looking at C4DPL_STARTACTIVITY for doing the plugin Init() instead of after Registering the plugin in PluginStart().  At a complete loss on reason why this fails.
            Thanks!
