    De-constructing a hierarchy
    General Discussion
    0
    • H
      On 26/11/2010 at 17:25, xxxxxxxx wrote:
      I need to create an algorithm that goes through a hierarchy of objects and rebuilds the list in a way that is would be able to rebuild the same hierarchy, later. Lets say:
      Cube1
      -Platonic1
      --SweepNURBS1
      ---Spline1
      ---Spline2
      --Cube2
      ---Platonic2
      ----Sphere1
      The order of creation is (I believe) :
      Cube1
      Platonic1 (insert_under Cube1)
      Cube2 ( (insert_under Platonic1)
      Platonic2 ( (insert_under Cube2)
      Sphere1 (insert_under Platonic2)
      SweepNURBS (insert_under Platonic1)
      Spline2 (insert_under SweepNURBS)
      Spline1 (insert_under SweepNURBS)
      This is because each time I InsertUnder, the inserted object ends up being the first child of its parent.
      Is there any algorithm that goes through a hierarchy and returns a list of objects in the correct order so that a new scene could be reconstructed?
      I already tried a few times to code such a thing but I'm having no luck 😞
      Anyone? Please...
      Rui Batsita
      • H
        On 27/11/2010 at 02:29, xxxxxxxx wrote:
        Then why don´t you use InsertAfter instead? 😉 Insert the SweepNurbs with InsertUnder, then user InsertAfter(sweepnurbs) for cube2. Then go through that hierarchy level again and start doing the same to sweep and cube2 for their children.
        • H
          On 27/11/2010 at 06:35, xxxxxxxx wrote:
          I need to automate the process. If I make it by hand, of course I would make it differently.
          But I need to be able to provide any hierarchy to my code and it must create a list in the correct order so that it could all be solved with InsertUnder.
          If there was an algorithm that would do what I need listing the objects in the correct order and having a flag telling that I should insert it with InsertUnder or InsertAfter, that would also be fine.
          • H
            On 27/11/2010 at 06:44, xxxxxxxx wrote:
            I don´t see why you wouldn´t be able to make a recursive function out of my suggestion.
            • H
              On 29/11/2010 at 16:44, xxxxxxxx wrote:
              Me neither 😉
              • H
                On 04/12/2010 at 16:39, xxxxxxxx wrote:
                The problem with InsertAfter is that it doesn't seem to work in Python. For example, the following code doesn't work inside a Python Generator:
                    parent=c4d.BaseObject(c4d.Osweep)
                    profile=c4d.BaseObject(c4d.Osplinecircle)
                    path=c4d.BaseObject(c4d.Osplinestar)
                    profile.InsertUnder(parent)
                    path.InsertAfter(profile)
                    return parent
                However, the following code does work:
                    path.InsertUnder(parent)
                    return parent
                But I need to insert the path before and then the profile, to create a sweep. This is harder than I thought 😞
