Forcing plugin registration order
On 16/11/2010 at 12:59, xxxxxxxx wrote:
Cinema 4D Version: 10.5-12
Platform: Windows ; Mac ; Mac OSX ;
Language(s) : C++ ;---------
Hi,I have two plugins (two seperate projects) and I would like to make sure that one of them is registered before the other one on Cinema 4D start up. Is there a way to control this, something like a priority queue? I kind of remember that there was a way to do so but I just don´t know where I read it or if my mind plays tricks on me.
thanks in advance
On 16/11/2010 at 22:23, xxxxxxxx wrote:
have a look at C4DMSG_PRIORITY in PluginMessage. I think that's what you need
On 17/11/2010 at 03:04, xxxxxxxx wrote:
thx will check it out
On 23/11/2010 at 05:44, xxxxxxxx wrote:
ok, unfortunately that´s not what I was looking for. Maybe I also simply didn´t make myself clear enough. What I need is that one plugin is initialised before the other, like plugin_a.cdl is loaded before plugin_b.cdl, so plugin_a.cdl can for example still remove plugin_b.cdl from disk.
Is there a way to accomplish this? is there maybe a lexicographical order C4D is loading plugins? Matthias?
thanks
On 23/11/2010 at 05:48, xxxxxxxx wrote:
ok, it seems c4d is indeed loading the plugins in lexicographical order. At least when I name the one plugin a.cdl and the other b.cdl, then I can remove b.cdl by a.cdl once it was loaded.
Now what I would need to know is if that is the case on all plattforms and if there is a guarantee that c4d loads them lexicographically.
Matthias could you ask the developers?
On 23/11/2010 at 07:08, xxxxxxxx wrote:
It seems that loading order of plugins is determined by the plugins folder hierarchy. So yes in general it's lexicographical but consider cases where a plugin resides within another plugin folder.
consider following hierarchy:
a1/ a1.cdl ... a3/ a3.cdl ... a2/ a2.cdl ...The plugins are loaded in the order a1, a3, a2 because a3 resides within a1.
Matthias -
On 23/11/2010 at 07:15, xxxxxxxx wrote:
ok, thanks Matthias. That clears it for me.
