    BaseDraw::GetObjectColor
    3 Posts 0 Posters 300 Views
      On 13/11/2010 at 08:03, xxxxxxxx wrote:
      Cinema 4D Version:   12
      my plugin draws some additional lines to specific spline objects. I want these lines to be in the color of the object. It works fine using BaseDraw::GetObjectColor if a color is set in the basis object properties. But if not, GetObjectColor returns the default object color of the document settings but not the color of the spline as it is drawn in the editor (black).
      Any hints?
      Thanks.
      Klaus
        On 18/11/2010 at 05:53, xxxxxxxx wrote:
        In this case you should check if a color is set otherwise use the "Shaded Wire" color (VIEWCOLOR_SHADEDWIRE).
          On 18/11/2010 at 06:12, xxxxxxxx wrote:
          ok, thanks. Hope that this isn't too bad for the performance when applying this within the Draw method.
