    Initialising Gradient
    9 Posts 0 Posters 1.3k Views
      On 08/11/2010 at 07:31, xxxxxxxx wrote:
      Cinema 4D Version:   12
      in pre R12 I used to initialise a gradient element like this in a shader::Init() :
         AutoAlloc<Gradient> gradient1;
        if (!gradient1) return FALSE;
        GradientKnot k1;
        k1.col =Vector(1.0,1.0,1.0);
        k1.pos =1.0;
        gradient1->InsertKnot(k1);
        k1.col =Vector(0.0,0.0,0.0);
        k1.pos =0.0;
        gradient1->SetData(GRADIENT_INTERPOLATION,GRADIENT_INTERPOLATION_LINEAR);
           data->SetData(DPIT_SMOKE_NOISE_GRADIENT,GeData(CUSTOMDATATYPE_GRADIENT,gradient1));
      In R12 however this doesn´t work anymore (the gradient is initialised completely white). How does it work in R12?
        On 08/11/2010 at 07:50, xxxxxxxx wrote:
        Ok, it seems the gradient IS correctly initialised but it anyway shows all the knots as white. And as soon as you touch the knots it indeed gets white. So is this a bug or am I doing anything wrong? It worked just fine before R12. 😕
          On 08/11/2010 at 07:56, xxxxxxxx wrote:
          Hm, looks ok to me.
          This is the code from the SDKGradient example:
          Bool SDKGradientClass::Init(GeListNode *node)
            BaseContainer *data = ((BaseShader* )node)->GetDataInstance();
            AutoAlloc<Gradient> gradient;
            if (!gradient) return FALSE;
            GradientKnot k1,k2;
            k1.col =Vector(0.0,0.0,1.0);
            k1.pos =0.0;
            k2.col =1.0;
            k2.pos =1.0;
            gradient->InsertKnot(k1);
            gradient->InsertKnot(k2);
            data->SetData(SDKGRADIENTSHADER_COLOR,GeData(CUSTOMDATATYPE_GRADIENT,gradient));
            data->SetBool(SDKGRADIENTSHADER_CYCLE,FALSE);
            data->SetLong(SDKGRADIENTSHADER_MODE,0);
            data->SetReal(SDKGRADIENTSHADER_ANGLE,0.0);
            data->SetReal(SDKGRADIENTSHADER_TURBULENCE,0.0);
            data->SetReal(SDKGRADIENTSHADER_OCTAVES,5.0);
            data->SetReal(SDKGRADIENTSHADER_SCALE,1.0);
            data->SetReal(SDKGRADIENTSHADER_FREQ,1.0);
            data->SetBool(SDKGRADIENTSHADER_ABSOLUTE,FALSE);
            On 08/11/2010 at 08:05, xxxxxxxx wrote:
            yeah, I also found this in the sdk and it seems to work in the sdk example. Any idea what might be the problem? It´s the same for all my gradients so it seems strange. I also looked up the resources and beside having the ICC_BASEDOCUMENT; flag (which I added now to mine too but didn´t change anything) there´s nothing new to it.
            Also in InitRender I call InitRender(irs) as in the sdk example but this doesn´t seem to change anything (well, how should it, it´s just the new call to pass irs). Could it be because I am in a MaterialData and not a ShaderData? Because in my ChannelShaders it works just fine!
              On 08/11/2010 at 08:10, xxxxxxxx wrote:
              hmm, no. I just added it to the simplematerial example and it works there. Argh, what could it be? I mean it worked before just fine and now in R12 it doesn´t. Did anything concerning resources convention change or similar? I am also using a custom material preview, could that be it? Also I am using the Obaselist for the material manager and the gradient is in a different GROUP.
                On 08/11/2010 at 08:28, xxxxxxxx wrote:
                Ah! It happens with the ALPHA flag only! This also happens in the simplematerial. So is this to be considered a bug?
                  On 08/11/2010 at 08:31, xxxxxxxx wrote:
                  Here is the changed code I used for testing in simplematerial:
                  class SimpleMaterial : public MaterialData
                    INSTANCEOF(SimpleMaterial,MaterialData)
                    private:
                        Vector color;
                        Gradient* grad;
                        virtual Bool Init        (GeListNode *node);
                        virtual    void CalcSurface            (BaseMaterial *mat, VolumeData *vd);
                        virtual    INITRENDERRESULT InitRender(BaseMaterial *mat, const InitRenderStruct &irs);
                        virtual    void FreeRender(BaseMaterial *mat)
                            if(grad) grad->FreeRender();
                    virtual Bool GetDParameter(GeListNode *node, const DescID &id,GeData &t_data,DESCFLAGS_GET &flags);
                    virtual Bool SetDParameter(GeListNode *node, const DescID &id,const GeData &t_data,DESCFLAGS_SET &flags);
                    virtual Bool Message(GeListNode* node, LONG type, void* data);
                    virtual Bool CopyTo(NodeData *dest, GeListNode *snode, GeListNode *dnode, COPYFLAGS flags, AliasTrans *trn);
                        static NodeData *Alloc(void) { return gNew SimpleMaterial; }
                    LONG updatecount;
                  Bool SimpleMaterial::Init(GeListNode *node)
                    BaseContainer *data=((BaseMaterial* )node)->GetDataInstance();
                    data->SetVector(SIMPLEMATERIAL_COLOR,1.0);
                    updatecount = 0;
                    GeData previewData(CUSTOMDATATYPE_MATPREVIEW, DEFAULTVALUE);
                    MaterialPreviewData* preview = (MaterialPreviewData* )previewData.GetCustomDataType(CUSTOMDATATYPE_MATPREVIEW);
                    if (!preview)
                    return FALSE;
                    data->SetData(SIMPLEMATERIAL_MAT_PREVIEW, previewData);
                    GradientKnot k1,k2;
                    k1.pos =0.0;
                    k2.col =1.0;
                    k2.pos =1.0;
                    data->SetData(SIMPLEMATERIAL_COLORG,GeData(CUSTOMDATATYPE_GRADIENT,gradient));
                  INITRENDERRESULT SimpleMaterial::InitRender(BaseMaterial *mat, const InitRenderStruct &irs)
                    BaseContainer *data=mat->GetDataInstance();
                    color = data->GetVector(SIMPLEMATERIAL_COLOR);
                    grad     = (Gradient* )data->GetCustomDataType(SIMPLEMATERIAL_COLORG,CUSTOMDATATYPE_GRADIENT);
                    if (!grad || !grad->InitRender(irs)) return INITRENDERRESULT_OUTOFMEMORY;
                    return INITRENDERRESULT_OK;
                  .h
                  enum
                    ID_TESTGROUP = 3000,
                    SIMPLEMATERIAL_COLOR        = 1000,
                    SIMPLEMATERIAL_MAT_PREVIEW  = 1001,
                  .res
                    GROUP ID_MATERIALPROPERTIES
                        DEFAULT 1;
                        COLOR     SIMPLEMATERIAL_COLOR {}
                    GROUP ID_TESTGROUP
                        GRADIENT SIMPLEMATERIAL_COLORG {ALPHA;}
                  .str
                    SIMPLEMATERIAL_COLOR    "Color";
                    SIMPLEMATERIAL_COLORG "Testgradient";
                    ID_TESTGROUP "Test";
                    On 08/02/2011 at 02:42, xxxxxxxx wrote:
                    Alpha gradients have to be set their mode before any knot is set.
                    Example:
                      //ust be set before any knot is set
                      gradient->SetData(GRADIENT_MODE, GeData(GRADIENTMODE_ALPHA));
                      GradientKnot k1,k2;
                      k1.pos =0.0;
                      k2.col =1.0;
                      k2.pos =1.0;
                    I will update the docs accordingly.
                      On 08/02/2011 at 02:54, xxxxxxxx wrote:
                      thank you Matthias. I confirm it's working fine now. super.
