    GetVirtualObject - double call ?
    4 Posts 0 Posters 431 Views
      On 05/11/2010 at 08:23, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      Language(s) :       PYTHON  ;
      I've got function (let say: GeneratePolys()) - which creates polygons (based on "Nr of Segment" value). Function is called from GetVirtualObject. When parameter is high it takes a few second to generate whole object and that's ok, but just after that Cinema calls GetVirtualObject one more time. I happens only when I use slider or arrows to change parameter value (and generation time takes a little longer) . If I enter it "manually" or generation time is short everything is ok. Anyone knows what is happening?
      Best
      Andrzej
        On 05/11/2010 at 09:17, xxxxxxxx wrote:
        Hi Andrzej, this behavior is currently normal and cannot be changed. The automatic cache
        already reduces the amount of unnecessary Python calls but changing the slider will update
        the object.
        C++ supports a BaseThread here, where you can abort your calculation while the user is using the slider, ...
        Cheers, Sebastian
          On 05/11/2010 at 09:56, xxxxxxxx wrote:
          ...changing the slider will update the object...
          Yes, of course, I understand. I don't want to abort calculation or change slider behavior. My problem is that after changing slider, Cinema calls GetVirtualObject, but when calculation takes too long it calls it again. So, there is double execution of "GetVirtualObject". As I wrote If calculation time is short (inside my function) everything is ok - I change slider, there is one "GetVirtu..." call and everybody are happy 🙂
          Andrzej
            On 05/11/2010 at 16:06, xxxxxxxx wrote:
            Ok. I simplified, checked, cleaned up the code. I check this code on another computer. Still the same. There is double call (and I think it is a bug). I uploaded code here. Could somebody check what is wrong?
            Manual (how to do the bug) 🙂
            1. Open python console
            2. Execute plugin "AM Tests"
            3. Enter 200000 in "Nr of points"
            4. It will take about 3-4 seconds to generate geometry. "2. GetVirtualObject" will appear in console. "Generating poly" will appear in status bar.
            5. Now. Clean up console.
            6. Change "Step" (or "Nr of points") parameter using slider
            7. Now it will take 6-8 seconds to generate geometry, because cinema will call "GetVirtual" twice. There will be "2. GetVirtualObject" * 2 and info on status bar will appear twice.
            Maybe I'm doing something wrong. I would be very grateful if somebody helped me.
            thanks, Andrzej
            AM Test
            from c4d import *
            import os, math, sys, random
            from c4d import plugins, utils, bitmaps
            PLUGIN_ID = 987653
            class AMTest(plugins.ObjectData) :
              """Test"""
              def __init__(self) :
                  self.SetOptimizeCache(True)
              def Init(self, node) :
                  #print "0. Init"
                  data = node.GetDataInstance()
                  data.SetLong(AMTEST_PTS, 200)
                  data.SetReal(AMTEST_STEP, .1)
              sweepProfile = [Vector()]*4
              sweepProfile[0] = Vector(-1, 0, 1)
              sweepProfile[1] = Vector(1, 0, 1)
              sweepProfile[2] = Vector(1, 0, -1)
              sweepProfile[3] = Vector(-1, 0, -1)
              def GenerateSweep(self, node, sp) :
                  swCnt = 4
                  spCnt = node[AMTEST_PTS]
                  pCnt = spCnt*swCnt
                  vCnt = (spCnt-1)*swCnt
                  StatusSetText ("Generating Poly")
                  op = PolygonObject(pCnt, vCnt)
                  for i in xrange(spCnt) :
                      StatusSetSpin()
                      spP = Vector(0,i*node[AMTEST_STEP], 0)
                      for j in xrange(swCnt) :
                          op.SetPoint(i*swCnt+j, Vector(spP.x + self.sweepProfile[j].x*10, spP.y, spP.z + self.sweepProfile[j].z*10))
                  for i in xrange(spCnt-1) :
                          nextj = (j+1)%swCnt
                          poly = CPolygon(i*swCnt+j, (i+1)*swCnt+j, (i+1)*swCnt+nextj, i*swCnt+nextj)
                          op.SetPolygon(i*swCnt+j, poly)
                      StatusSetBar(100.0*(1.0*i*swCnt/pCnt))
                  op.Message(MSG_UPDATE)
                  StatusSetBar(100.0)
                  return op
              def GetVirtualObjects(self, op, hierarchyhelp) :
                  timerStart = GeGetMilliSeconds()
                  print "2. Get Virtual Objects"
                  StatusSetSpin()
                  po = self.GenerateSweep(op, False)
                  StatusClear()
                  StatusSetText ("Done in: %s s" % ((GeGetMilliSeconds()-timerStart)/1000))
                  return po
              path, file = os.path.split(__file__)
              plugins.RegisterObjectPlugin(id=PLUGIN_ID, str="AM Tests",
                                          g=AMTest,
                                          description="Oamtest", icon=None,
                                          info=OBJECT_GENERATOR|OBJECT_POLYGONOBJECT)
              plugins.Update()
