    Multiple newline escape characters
    12 Posts 0 Posters 997 Views
      On 30/10/2010 at 16:59, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Platform:      Mac OSX  ;
      With the line of code:
      println("This is the first line\n\n\nAnd this should be three lines down");
      I should get the following output:
      **This is the first line
      And this should be three lines down**
      However I get this:
      Why aren't the multiple newline escape characters creating multiple newlines?
      Rui Batista
        On 30/10/2010 at 17:09, xxxxxxxx wrote:
        Try adding "\r\n" for each newline, or try adding an empty space " \n \n" before each newline.
          On 30/10/2010 at 17:35, xxxxxxxx wrote:
          None of those methods worked. The first one (\r\n) returns an error and I can't add spaces at the beginning of lines. What I'm trying to do is to create a script that generates Python code. I would like to be able to leave empty lines to separate bits of code. But Python is very strict with space indenting lines.
          Shouldn't the \n\n\n work? Is it a bug?
            On 30/10/2010 at 19:07, xxxxxxxx wrote:
            As far as I know, \r is a valid escape sequence for Python and other programming languages.
            \r\n = CR+LF
            On a typewriter, LF would move the line down, and CR would move the cursor position back to the left.
              On 31/10/2010 at 01:16, xxxxxxxx wrote:
              Well, I know that those are supposed to be carriage return + linefeed. But I'm generating the string in COFFEE. When I use that string as a Python script, all the \n are treated as one 😞
                On 31/10/2010 at 02:54, xxxxxxxx wrote:
                Why not put a comment marker(#) where you want a blank line? It's not quite whitespace, but it's almost as good.
                println("This is the first line\n#\n#\nAnd this should be three lines down");
                  On 31/10/2010 at 06:50, xxxxxxxx wrote:
                  simply put a space in between them:
                  println("This is the first line\n \n \nAnd this should be three lines down");
                    On 31/10/2010 at 11:45, xxxxxxxx wrote:
                    The problem with adding spaces is that Python is very picky with spaces at the beginning of lines. Indentation define code blocks. I guess I will have to use comments.
                    But why can't I set multiple newlines without adding a character to each line?
                    Rui Batista
                      On 31/10/2010 at 11:59, xxxxxxxx wrote:
                      Oh I haven´t seen that you want to output python code. haven´t used python yet so I think I cannot be of much help but isn´t python intendation tabbed and not spaced?
                        On 31/10/2010 at 12:24, xxxxxxxx wrote:
                        Ok, then, how about an invisible tab?
                        " \n"
                        If that doesn't work, then try writing your escape sequences in hex form, "\x0a".
                          On 31/10/2010 at 15:35, xxxxxxxx wrote:
                          Well, the "\n " works, kind of... however, I read somewhere that Python prefers indentation based on spaces instead of tabs.
                          Rui Batista
                            On 03/11/2010 at 07:12, xxxxxxxx wrote:
                            println should only be used to print a line into the console. If you want to print several lines you have to call println for each line.
