    Born with user data
    7 Posts 0 Posters 669 Views
      On 17/10/2010 at 10:53, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      Hi all !
      I need to create an object or a tag with userdata on it. I haven't found a way to do this by myself... No problem to create the object or the tag, but I can't add userdatas to it.
      Do we need to add a container for user data ? Or is it a command line I missed...
      Maybe do you have the solution.
      Mike
        On 17/10/2010 at 12:10, xxxxxxxx wrote:
        afaik there is no way via COFFEE.
          On 17/10/2010 at 14:02, xxxxxxxx wrote:
          OUCH ! Possible via C++ ?
          Thank you
            On 17/10/2010 at 14:04, xxxxxxxx wrote:
            Yes it is
              On 17/10/2010 at 14:09, xxxxxxxx wrote:
              Katachi, to your opinion, is it difficult to translate C.O.F.F.E.E into C++ ?
              Are these languages far one from the other or quite similar ?
              And my last one : Is C++ The most powerfull language for Cinema4D coding ? or each one of MEL, COFFEE and C++ have it's own advantages on others ?
              Sorry, I'd just like to know if I'd better turn to C++ now ... or learn both C++ and COFFEE.
                On 17/10/2010 at 14:25, xxxxxxxx wrote:
                Translation depends on your experience and knowledge of the languages. In the end, you can translate almost any language into the other as the basic concepts of all languages are the same.
                COFFEE has approximately the same syntax as C++ and it uses approximately the same function naming conventions so it´s really not that hard. Of course there is no real object oriented programming in COFFEE, also there is so much more in C++ that can be done which is simply impossible in COFFEE (templates, polymorphism, inhertage etc.).
                It depends on what you would like to do. If you want to code full blown plugins there is no other choice than turning to C++, but if you want to create small and useful plugins you could also get away with using Python. But for full access C++ is the way to go. But once you work with C++ you won´t go back to COFFEE, that´s what the experience shows. I started with COFFEE too but once I was in C++...COFFEE what?
                Cinema 4D only supports C++ so there is no real alternative. But C++ is a great language and there is a reason it is the most used language on earth in application programming (also an advantage of not having a fully object-oriented programming language, it can at the same time completely be used for system programming), it´s fast, it´s flexible and it´s fun (well, most of the time). But that´s also a matter of taste and application target I´d say. Java is a great language too and C# is also pretty cool I must say. But fully Object oriented languages like Smalltalk also have their advantages, well there is a long list. If you go C++ it´s an excellent choice in any case.
                MEL is specific to Maya so it´s not really comparable but it seems to allow full access to nearly everything in Maya which is just what is necessary for adding stuff to an existing main application. But I never worked with it so I cannot really say anything about it to be honest, I also don´t know about its performance. But it´s no option for C4D anyway, so screw it.
                  On 17/10/2010 at 14:54, xxxxxxxx wrote:
                  Lots of thanks Katachi I've my answer, I'll turn to C++.
                  Again thank you A LOT for such an accurate answer !
                  C.O.F.F.E.E enjoys me a lot, but I'm really affraid of limitations and if I found some real one after only 2weeks... It seems not good ...
                  I'm also quite used to JAVA with Adobe scripting and I know I can switch to C++ there too, so that'll be perfect !
                  Mike
