    Camera Switching
    6 Posts 0 Posters 774 Views
      On 14/10/2010 at 01:31, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      Hi !
      The goal is to make a camera the active one when it is selected...
      I can't get it work. (C4D 11.5).
      The C.O.F.F.E.E Tag is on the camera itself.
      main(doc,op) {
      var bd,cam;
      cam=op;
      bd = doc->GetActiveBaseDraw();
      bd->SetSceneCamera(cam);  <- this always returns "Member not found" ...
      Thanks for help.
        On 14/10/2010 at 08:32, xxxxxxxx wrote:
        Something like this should work:
        main(doc,op)
          var bd = doc->GetActiveBaseDraw();
          bd#BASEDRAW_DATA_CAMERA = op;
          On 14/10/2010 at 08:57, xxxxxxxx wrote:
          just to add. SetSceneCamera member is not available in COFFEE, that´s why it wouldn´t work int he first place and gives you this message. Matthias code works just fine though.
            On 14/10/2010 at 13:53, xxxxxxxx wrote:
            It works great ! That was so simple, I think I saw it when I explored BaseDraw.h, I didn't deduced it was the one :D...
            So Matthias, 3D Designer, my question is now :
            Why "SetSceneCamera()" isn't available in C.O.F.F.E.E. although it is in the C.O.F.F.E.E. SDK I just picked up on www.Plugincafe.com ?
            Is there a way to know which commands works with C.O.F.F.E.E. and which one doesn't ?
            Lots of thanks !
            void SetSceneCamera(BaseObject* op)_<_h4_>_
            Sets a new scene camera. If op is NULL, the editor camera is used._h5> _Paramet_ <_h5_>_i>
            > BaseObject* op
            >> The new camera.
              On 14/10/2010 at 14:21, xxxxxxxx wrote:
              I just downloaded the coffee docs and I don´t see this command documented. Are you sure you didn´t download teh c++ sdk docs?
                On 14/10/2010 at 15:44, xxxxxxxx wrote:
                woops ... Seems like you're right ... It is less complicated than the C++ one, and I guess less powerfull too...
                Thank you again !
                Mike
