    When scaling fails
    3 Posts 0 Posters 282 Views
      On 12/10/2010 at 16:18, xxxxxxxx wrote:
      Cinema 4D Version:   R10-R12
      Which built-in object types will not respond to changes of their scaling values?  For instance, changing the Scale of a Sweep NURBS has no effect on the results - one must scale the underlying spline objects.  Any others of which to be aware (only generators or such)?
      ETA: This may be related to the fact that they are also Instances. 😞
      Thanks!
        On 27/10/2010 at 02:11, xxxxxxxx wrote:
        Sorry I can't confirm. Scaling seems to work fine with all objects I tested. The only exception is the Hair object which does not scale the hair guides.
          On 27/10/2010 at 09:28, xxxxxxxx wrote:
          And I can confirm that it can't be confirmed. 🙂
          Must have had C4D in some odd configuration because I couldn't get Nulls or Sweep NURBS to scale the results.  Now it seems to be working.  Moving on... 😉
