    Render camera
    3 Posts 0 Posters 312 Views
      On 06/10/2010 at 02:17, xxxxxxxx wrote:
      Cinema 4D Version:   11.5/12
      Hello all,
      i have a problem on my videopost plugin.
      i use videopost to export current document and send scene to an external renderer.
      i need to export all camera in the scene and "mark" the active camera.
      now i am making a recursion in real document and if i find a camera i export it and after i check if is the current render camera with:
      if ( mycam == bd->GetSceneCamera(Mydoc)) exporter.setscenecamera(mycam)
      where my cam is the BaseObject i am exporting.
      but my cam and bd->GetSceneCamera(Mydoc) have alwaise 2 differentpointer, and my plugin don't work 😞
      why this ?
      is the scene camera from basedraw internaly cloned?
      if yes is there a way to have a link to original camera object from the doument?
      thanks in advance
      Franz
        On 07/10/2010 at 02:07, xxxxxxxx wrote:
        From where do you get mycam? Where in the code do you compare the cameras and where do you get the Basedraw from?
        In a video post effect you can access the camera through the VolumeData (if it is avaible). VolumeData::GetRayCamera. RayCamera has also a link to the real camera, RayCamera::link.
          On 07/10/2010 at 05:52, xxxxxxxx wrote:
          thanks 🙂
          i solved... my mistake i was get the cameras from 2 different document
          Bets
          Franz
