    is the "connect object" available as a BaseObject
    4 Posts 0 Posters 416 Views
      On 01/10/2010 at 16:14, xxxxxxxx wrote:
      Cinema 4D Version:
      i am just wondering if the "connect object" is available as a BaseObject, just like Ocube or others?
      I cannot find it, but it is available in cinema as a object type.. can i use it the same within a Generator Plugin?? it would be much better than using ModellingCommand plus i actually dont know if i can even use a ModellingCommand with VirtualObjects...
      thanks for your intput..
      Ello
        On 04/10/2010 at 05:25, xxxxxxxx wrote:
        The ID of the Connect object is 1011010.
        You can always get the ID of objects/tags etc. by dragging them into the command field of the Cinema console and print the type.
        See here:
          On 04/10/2010 at 05:45, xxxxxxxx wrote:
          ok, i tried that and it didnt work. so there must have been another error somewhere
            On 04/10/2010 at 07:01, xxxxxxxx wrote:
            This code is working for me. It simply returns a Connect object in GetVirtualObjects(). You can see it if you make the object editable.
            BaseObject *RoundedTube::GetVirtualObjects(BaseObject *op, HierarchyHelp *hh)
              BaseObject *ret = NULL;
              Bool dirty = op->CheckCache(hh) || op->IsDirty(DIRTYFLAGS_DATA);
              if (!dirty) return op->GetCache(hh);
              ret = BaseObject::Alloc(1011010);
              if (!ret) return NULL;
              return ret;
