    Reset Bind Pose
    12 Posts 0 Posters 1.3k Views
      On 30/09/2010 at 16:36, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      In Cinema 4D, there's a button called "Reset Bind Pose" in the weight tag properties dialog.
      Can this command be called through the C++ SDK?  If so, how?
      If not, then how can I re-create what it does in SDK code?
        On 01/10/2010 at 01:30, xxxxxxxx wrote:
        You can do this by sending a MSG_DESCRIPTION_COMMAND to the button.
        here how it goes:
        DescriptionCommand dc;
        //fill with the ID of the button; include _tcaweight.h_
        dc.id = DescID(DescLevel(ID_CA_WEIGHT_TAG_RESET));
        //send the message to the weight tag
        tag->Message(MSG_DESCRIPTION_COMMAND, &dc);
          On 01/10/2010 at 08:19, xxxxxxxx wrote:
          Thanks, I found the definition.
          I tried doing this in C++ SDK, but my scene doesn't change.
          #define ID_CA_WEIGHT_TAG_RESET 2001
          CAWeightTag* wt = (CAWeightTag* ) (ob->GetTag(Tweights));
          wt->Message(MSG_DESCRIPTION_COMMAND, &dc);
          DrawViews(DRAWFLAGS_FORCEFULLREDRAW);
          Do I have to call something else to see the results of my sent message?
            On 01/10/2010 at 10:35, xxxxxxxx wrote:
            When I click on the "Reset Bind Pose" button by hand, I can see changes being made.
            My character snaps back to its bind pose.  But, when I call it from my plugin, nothing happens.
            Here's what I tried so far, somewhat bit of desperate overkill:
             dc.id = DescID(DescLevel(ID_CA_WEIGHT_TAG_RESET)); // button ID
             wt->Message( MSG_DESCRIPTION_COMMAND, &dc );  // send message to button
             ob->Message( MSG_DESCRIPTION_COMMAND, &dc );
             doc->Message( MSG_DESCRIPTION_COMMAND, &dc );
             wt->Message(MSG_POLYGONS_CHANGED);
             wt->Message(MSG_UPDATE_NGONS);
             wt->Message(MSG_CHANGE);
             wt->Message(MSG_UPDATE);
             ob->Message(MSG_POLYGONS_CHANGED);
             ob->Message(MSG_UPDATE_NGONS);
             ob->Message(MSG_CHANGE);
             ob->Message(MSG_UPDATE);
             doc->Message(MSG_POLYGONS_CHANGED);
             doc->Message(MSG_UPDATE_NGONS);
             doc->Message(MSG_CHANGE);
             doc->Message(MSG_UPDATE);
             EventAdd(EVENT_FORCEREDRAW);
             // nothing! !`Dead`[URL-REMOVED]
              On 04/10/2010 at 06:40, xxxxxxxx wrote:
              Hm, it's working fine here.
              Here my test code:
              BaseObject *op = doc->GetActiveObject();
              if (!op) return FALSE;
              BaseTag *tag = op->GetTag(Tweights);
              if (!tag) return FALSE;
              EventAdd();
                On 04/10/2010 at 09:01, xxxxxxxx wrote:
                Thanks, I commented out everything except EventAdd(), and it started working.  Awesome. !Smile[URL-REMOVED]
                When I added this line, my scene didn't change:
                Calling DrawViews() seems to erase my bind pose, and force it into an animated pose again.
                I was just wondering, if I were call EventAdd() and then DrawViews(), is there some way to refresh
                the viewport so I can see the results of EventAdd() before calling DrawViews() ?  Without forcing
                the scene into an animated pose?
                  On 04/10/2010 at 09:34, xxxxxxxx wrote:
                  Here's my problem.  When I export a scene, the mesh's vertices are in a bind pose.  However, the document objects are in an animated pose.
                  I was thinking I could just use the ResetBindPose button, but that might be problematic.
                  Using the C++ SDK, how can I transform my mesh's bind pose vertices into an animated pose?
                  Is there a SDK function that can help me do this?
                    On 05/10/2010 at 05:55, xxxxxxxx wrote:
                    I am not sure if I can follow you here. If you just want to get the current state of the mesh you have to use SendModelingCommand() with MCOMMAND_CURRENTSTATETOOBJECT. There is an example in the SDK docs.
                      On 05/10/2010 at 11:17, xxxxxxxx wrote:
                      Thanks, I tried it, but when I send it a polygon object, I'm getting back a "Onull" object with zero vertices/polys.
                          if(ob->GetType() == Opolygon) {
                             BaseContainer bc;
                             ModelingCommandData dat;
                             dat.doc  = ob->GetDocument();
                             dat.op   = ob;
                             dat.bc   = &bc;
                             dat.mode = MODELINGCOMMANDMODE_ALL;
                             // this doesn't help
                             //bc.SetData( MDATA_CURRENTSTATETOOBJECT_INHERITANCE, TRUE );
                             //bc.SetData( MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION, TRUE );
                             BOOL br = SendModelingCommand( MCOMMAND_CURRENTSTATETOOBJECT, dat );
                             BaseObject* res = static_cast<BaseObject*>(dat.result->GetIndex(0));
                             if(br && res) {
                                // "Onull" !
                             AtomArray::Free(dat.result);
                      Does this look correct?
                        On 06/10/2010 at 20:32, xxxxxxxx wrote:
                        Ok, I fixed the "Onull" problem.  But I hit a dead end again.  The joint list for the converted polygon returns NULL joint objects.
                        Looks like I went full circle back to the joint bug again!
                        All I really need is the mesh and the object hierarchy to be in the same frame of reference.
                        And the most desirable frame of reference is the bindpose.  And everything else, such as
                        joints, weights, and animation, must stay intact.
                          On 07/10/2010 at 02:11, xxxxxxxx wrote:
                          I am sorry but I can't really follow you. Please tell me what you are trying to achieve? It seems you are writing some sort of exporter, what do you exactly want to export?
                            On 07/10/2010 at 11:09, xxxxxxxx wrote:
                            I'm exporting an animated character model with joints, using my own plugin.  And the reason
                            why I'm having so many problems, is that the CAWeightTag joint-list goes missing (joint objects
                            return NULL) when converting the mesh with MCOMMAND_CURRENTSTATETOOBJECT.
                             I've noticed that Polygonize() also calls MCOMMAND_CURRENTSTATETOOBJECT, so I see now where the problem lies.
                            I tried cloning it first, but no luck there.  And I always make sure I'm passing the original document, but still no luck.
