    image in description?
    6 Posts 0 Posters 621 Views
      On 29/09/2010 at 13:17, xxxxxxxx wrote:
      Cinema 4D Version:   11 / 12
      Hi there,
      can somebody quickly point me towards how i can add images to my description?
      I'd like to add some small icons next  to my parameters.
      is that possible? maybe in the res file?
      cheers and thanks,
      ello
        On 29/09/2010 at 14:21, xxxxxxxx wrote:
        It is possible but not simple.  If you don't want them to be buttons, just omit BUTTON from the .res file:
        // Ogreebler.res
        CONTAINER Ogreebler
          NAME    Ogreebler;
          INCLUDE Obase;
          GROUP ID_OBJECTPROPERTIES
              DEFAULT            1;
              // Help and Information about Greebler
              BITMAPBUTTON    GREEBLER_INFO                                { ANIM OFF; BUTTON; }
        // GreeblerObject.cpp
        // NodeData.Message
        Bool GreeblerObj::Message(GeListNode* node, LONG type, void* data)
          if (!node)    return FALSE;
          if        (type == MSG_DESCRIPTION_GETBITMAP)
              return MsgGetBitmap(static_cast<DescriptionGetBitmap*>(data), static_cast<BaseObject*>(node));
          return SUPER::Message(node,type,data);
        // GreeblerObj.MsgGetBitmap
        Bool GreeblerObj::MsgGetBitmap(DescriptionGetBitmap* dgb, BaseObject* op)
          if (!(dgb && op))        return TRUE;
          BaseContainer*    bc =    op->GetDataInstance();
          LONG            id =    dgb->id[0].id;
          if (id == GREEBLER_INFO)
              Filename    bg =    GeGetPluginPath()+Filename("res")+Filename("banner.tif");
              if (!GeFExist(bg))    return TRUE;
              AutoAlloc<BaseBitmap>    bm;
              bm->Init(bg);
              dgb->bmp =            bm.Release();
        // NodeData.GetDParameter
        Bool GreeblerObj::GetDParameter(GeListNode* node, const DescID& id, GeData& t_data, DESCFLAGS_GET& flags)
          LONG    did =    id[0].id;
          switch (did)
              // BitmapButtons
              case GREEBLER_INFO:
                  BitmapButtonStruct bbs(static_cast<PluginObject*>(node), id, 0L);
                  t_data =        GeData(CUSTOMDATATYPE_BITMAPBUTTON, bbs);
                  flags |=        DESCFLAGS_GET_PARAM_GET;
                  break;
              default:
                  break;
          return SUPER::GetDParameter(node, id, t_data, flags);
        // NodeData.SetDParameter
        Bool GreeblerObj::SetDParameter(GeListNode* node, const DescID& id, const GeData& t_data, DESCFLAGS_SET& flags)
          // Info BitmapButton
          if (did == GREEBLER_INFO)
              if (flags & DESCFLAGS_SET_USERINTERACTION)
                  // user clicked on button - open Dialog
                  greebler->ShowHelpDialog();
              flags |=    DESCFLAGS_SET_PARAM_SET;
          return SUPER::SetDParameter(node, id, t_data, flags);
          On 29/09/2010 at 23:08, xxxxxxxx wrote:
          Omg.. thank you for that. This is quite a lot to just display an image 🙂 And i was planing to add a picture to all parameters because they are hard to describe by words.
          Lets see if i can get that to work...
          kind regards,
          ello
          edit: just wanted to say thank you.. i got it working 🙂
            On 01/10/2010 at 05:53, xxxxxxxx wrote:
            just one more question: how can i use a bitmap which contains a bunch of symbols and adress them via an offset? somehow like cinema does it with its interface icons?
            thanks for any input..
            ello
              On 01/10/2010 at 09:06, xxxxxxxx wrote:
              Load the big image and copy the part you need to the the allocated basebitmap.
                On 01/10/2010 at 09:18, xxxxxxxx wrote:
                thank you very much for the hint...
