    Joint Bug?
    4 Posts 0 Posters 427 Views
      On 28/09/2010 at 16:46, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      After calling Polygonize() on a document, calling GetJoint() on CAWeightTag returns NULL.
      However, GetJointCount() still returns a valid count.
      If I don't call Polygonize(), then everything works as expected.
      CAWeightTag* wt = (CAWeightTag* ) (ob->GetTag(Tweights));
      LONG joint_count = wt->GetJointCount();   // valid count
      for (LONG i=0; i < joint_count; i++) {
         BaseObject *joint_ob = wt->GetJoint( i, doc ); // returns NULL!
      Also, is Polygonize(TRUE) buggy?  Because my scene doesn't animate after I call Polygonize(TRUE) on a document.
      What specific animation properties are lost if I don't pass TRUE?
        On 30/09/2010 at 06:45, xxxxxxxx wrote:
        I can confirm the Joint bug. Strangely it seems only to happen with R12 files. Polygonizing pre-R12 files will list the Joints.
        Polygonize(TRUE) seems to work fine here.
          On 30/09/2010 at 07:15, xxxxxxxx wrote:
          Ok, it seems to work if the mesh and the joints share the same parent object. It has nothing to do with pre-R12 files after all. I will report it as a bug.
            On 30/09/2010 at 17:34, xxxxxxxx wrote:
            Thanks!  I guess will have to avoid calling it for now.
