    Getting basic animation info
    3 Posts 0 Posters 251 Views
      On 25/09/2010 at 18:25, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      I'm trying to get some basic animation info from Melange, but I've been having difficulties.
      How can I get the start/end frame?
      The BaseDocument doesn't have GetMinTime() or GetMaxTime(), unlike the C++ SDK, and the docpref member is private.
      // doesn't work
      LONG start_frame = c4ddoc.docpref.GetMinTime().GetFrame(c4ddoc.GetFps());
      LONG end_frame   = c4ddoc.docpref.GetMaxTime().GetFrame(c4ddoc.GetFps());
      There are no methods in BaseDocument that explicitly return docpref, so I have no idea how to access it.
        On 30/09/2010 at 01:43, xxxxxxxx wrote:
        Most of the attributes you can set/get with SetParameter()/GetParameter().
        (to get the name of a parameter you can drag it from the attribute manager into the edit field of the console window in cinema)
        to get min and max frames please try this:
        _GeData mydata;
        Real start_time = 0.0, end_time = 0.0;
        LONG start_frame = 0, end_frame = 0, fps = 0;
        // get fps
        if (c4ddoc.GetParameter(DOCUMENT_FPS,mydata))
        fps = mydata.GetLong();
        // get start and end time
        if (c4ddoc.GetParameter(DOCUMENT_MINTIME,mydata))
        start_time = mydata.GetTime().Get();
        if (c4ddoc.GetParameter(DOCUMENT_MAXTIME,mydata))
        end_time = mydata.GetTime().Get();
        // calculate start and end frame
        start_frame = start_time * fps;
        end_frame   = end_time * fps;_
        Jens
          On 30/09/2010 at 17:32, xxxxxxxx wrote:
          Thanks for the help!
