    Version/System checks
    17 Posts 0 Posters 2.3k Views
      On 22/09/2010 at 08:54, xxxxxxxx wrote:
      But the information in the PDF is not explicit and there has been some conflicting information from other sources.  Not enough info and one single, tiny example would have sufficed to remove all doubt. 🙂
        On 22/09/2010 at 09:15, xxxxxxxx wrote:
        Since Maxon doesn't give developers a switch so we can test this information
        Demo and Time restricted demo are different binaries, there is no switch; NET and command line versions can be started by using a command line parameter that you specify.
        I'm putting a user through some paces.Here is what I have.  Is it correct?
        Yes
          On 22/09/2010 at 09:17, xxxxxxxx wrote:
          If SYSTEMINFO is an enum (and I believe you), then what about this: _
          SYSTEMINFO_SAVABLEDEMO_ACTIVE_
          Activated savable demo version, SYSTEMINFO_SAVABLEDEMO[URL-REMOVED] is still set.
          You cannot have two values set if they are not | together (boolean operator).
          As I said: conflicting information.  Need example or explicitly clear documentation.
            SYSTEMINFO is a flag set (please take at a look at the end of an enum: ENUM_END_FLAGS vs. ENUM_END_LIST). More infos can be found in the R12 transition document under 1.3 Constants and Flags
              Can the demo version (which I downloaded yesterday) be install along side the registered version without an ill consequences?
              Thanks! 🙂
                Please point me to where there is any conflicting information?
                  Thanks for clearing that up, Philip!  As I said, not as explicit as it at first appears.
                    Can the demo version (which I downloaded yesterday) be install along side the registered version without an ill consequences?Thanks! 🙂
                    Yes - you can have multiple folders with all kinds of different C4D installations (Demo, NET, different versions and builds).
                      On 22/09/2010 at 09:30, xxxxxxxx wrote:
                      There was some post somewhere that I read that said not to use boolean operators on the SYSTEMINFO returned.  And reading the transition PDF it is possible to interpret it that way:
                      _Before R12 GeGetVersionType returned a flag set that could combine several values. Now
                      you'll get exactly one enumeration value, specifying what version of C4D is running.
                      For a precise overview which features are present in all editions please visit the official
                      website www.maxon.net
                      Independent of GeGetVersionType you can retrieve the following information from
                      GeGetSystemInfo:
                      _
                      There is no explicit notation that GeGetSystemInfo() is flags or singular enumerations.
                      After looking at the SDK Docs, it says 'flags' so I assumed that this was more official and the reason that I went that way.
                      Similarly, you assume Cinema 4D is running 64-bit and don't display that on the splash during load but you show [32-bit] otherwise.  Why not remove ALL ambiguity and simply have [32-bit] or [64-bit] displayed.  Since you've reverse this notation from previous versions, I'll wager that you will have confused users.  If I've learned anything while developing, explicit, while boring, is always better than implicit.  Never ass-u-me.
                        On 22/09/2010 at 09:31, xxxxxxxx wrote:
                        Thanks for the info and the pointer to the 1.3 chapter. Well, I found it a bit confusing too probably because the information on GeGetVersionType and GeGetSystemInfo are so near with a statement of a specific enumeration. But 1.3 indeed clears it up. thx
                          On 23/09/2010 at 13:58, xxxxxxxx wrote:
                          As a somewhat more "casual" coder I do find these small changes
                          a bit confusing.
                          So Roberts examples covers -ALL- versions?
                          Trying to see/understand the different needed options:
                          For GeGetVersionType() we must use a compare "=="
                          and for GetSystemInfo() we must use bolean "&"   ???
                          What about SysGetUserInfo() to return "0" (for regular Cinema)
                          and SysGetUserInfo() to return "6" for MutiLicenseServer?
                          Is SysGetUserInfo() still valid returning 0 or 6?
                          It is also a bit complicated to check every aspect since
                          as far as I can tell the NET versions are not in par
                          (NET 12.016 App 12.021)
                          Lennart
                            On 23/09/2010 at 14:39, xxxxxxxx wrote:
                            With SysGetUserInfo() I meant:
                            SysGetUserInfo(0) returns the local "normal" Cinema serial
                            and SysGetUserInfo(6) returns the MultiLicense serial.
                            Lennart
