    UI element like the one in the target tag?
    3 Posts 0 Posters 386 Views
      On 14/09/2010 at 05:29, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      Platform:      Mac OSX  ;
      I want to re-create the Target-tag in COFFEE just for practising purposes. But is it possible to create the UI element for the first field in the tag - the 'Target Object', where you can drag&drop; the object you want to point at? Will it behave in the same way as in the original tag (e.g. with the little combo box on the right)?
      Thanks for any help.
        On 14/09/2010 at 07:15, xxxxxxxx wrote:
        COFFEE plugins don't support the Attribute manager descriptions and several of the custom GUI elements. My advice is please don't waste your time. COFFEE will be probably still supported for some versions to come but it is likely to be replaced completly by Python.
          On 14/09/2010 at 08:43, xxxxxxxx wrote:
          COFFEE plugins don't support the Attribute manager descriptions and several of the custom GUI elements. My advice is please don't waste your time. COFFEE will be probably still supported for some versions to come but it is likely to be replaced completly by Python.cheers,Matthias
          OK, thank you!
