    Using C4D Constants in Python
    8 Posts 0 Posters 738 Views
      On 09/09/2010 at 11:11, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Language(s) :       PYTHON  ;
      Hi all,
      I can't seem to figure out how to use c4d constants in my python code. For example, I want to use the the c4d.documents.SaveDocument function. It has these saveflags:
      SAVEFLAG_SHOWERROR
      _SAVEFLAG_SAVEAS
      _ SAVEFLAG_DONTADDTORECENTLIST
      SAVEFLAG_AUTOSAVE
      _<_dt id="c4d.s.save"_>_I've tried using c4d.SAVEFLAG_SHOWERROR and c4d.documents.SAVEFLAG_SHOWERROR, but those don't work. I can lookup the number that represents these flags in coffeesymbols.h, but obviously I would prefer to use the constant's name instead. 🙂
      I couldn't find any info about this in the python documentation I downloaded from the plugin cafe site, so any help would be appreciated.
      - Ryan
        On 09/09/2010 at 11:26, xxxxxxxx wrote:
        Hi Ryan,
        it seems the old constants for SaveDocument are still in the documentation.
        Here are the correct constants:
        SAVEDOCUMENTFLAGS_0
        SAVEDOCUMENTFLAGS_DIALOGSALLOWED
        SAVEDOCUMENTFLAGS_SAVEAS
        SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST
        SAVEDOCUMENTFLAGS_AUTOSAVE
        SAVEDOCUMENTFLAGS_SAVECACHES
        SAVEDOCUMENTFLAGS_EXPORTDIALOG
        An update of the documentation will be available soon.
        Cheers, Sebastian
          On 09/09/2010 at 11:37, xxxxxxxx wrote:
          Thanks for the info! There are a couple others I need at the moment if possible.
           - The SaveDocument function also takes a format flag, and I want to pass FORMAT_C4DEXPORT.
           - The GeDialog.GroupBorder function takes a borderstyle flag, and I want to pass BORDER_THIN_IN.
          I think that's all I need for now.
          Thanks!
           - Ryan
            On 09/09/2010 at 11:44, xxxxxxxx wrote:
            All constants in Python of R12 are defined in the main module. Also the GroupBorder and SaveDocument constants.
            Cheers, Sebastian
              On 09/09/2010 at 12:11, xxxxxxxx wrote:
              Ah, cool. Sorry about that, I thought those might have had new names as well.
              - Ryan
                On 09/09/2010 at 12:46, xxxxxxxx wrote:
                One more question related to the c4d.documents.SaveDocument function. I noticed that if I pass the active document as a parameter, it saves it just fine, but this isn't reflected in the C4D UI. It appears that I've just saved a copy of the active document, as opposed to saving the actual active document. I hope that made sense. 🙂
                When I used COFFEE in the past, I used the active document's Save function, which accepted a file name, and this seemed to work fine. However, the python docs don't show a similar Save function for the BaseDocument class, which is why I originally used the c4d.documents.SaveDocument function.
                So I guess I have 2 questions:
                1. Is there a Save function for the BaseDocument class that isn't documented?
                2. If not, is there a way to save the actual active document, as opposed to just saving a copy of it?
                Thanks!
                 - Ryan
                  On 09/09/2010 at 14:11, xxxxxxxx wrote:
                  There is no un-documentated save function. You can simulate the Save-Process by calling CallCommand(saveid), does this help?
                    On 10/09/2010 at 06:47, xxxxxxxx wrote:
                    That works great! Thanks again for your help.
