    R12 SDK compile Errors
    7 Posts 0 Posters 521 Views
      On 04/09/2010 at 12:05, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      Platform:      Mac OSX  ;
      Howdy,
      I'm getting 2 compile errors when trying to compile the R12 SDK from the demo:
      /Developer/usr/bin/libtool filed with exit code 1
      ... and:
      /Developer/usr/bin/g++-4.2 failed with exit code 1
      I'm on a 2Ghz intel core duo Macbook pro running MacOSX 10.6.4, using Xcode 3.2.3.
      Adios,
      Cactus Dan
        On 04/09/2010 at 12:25, xxxxxxxx wrote:
        Howdy,
        OK, never mind. It was a simple folder permissions issue. DOH!
        Adios,
        Cactus Dan
          On 04/09/2010 at 12:31, xxxxxxxx wrote:
          Hey Dan,
          I recall me having the same problem, yet I dont recall how I solved it...
          Can you maybe point out which file permissions you had to change in case anyone else(likely me) runs into this? 🙂
            On 04/09/2010 at 16:54, xxxxxxxx wrote:
            Howdy,
            I just changed the permisions of the entire Cinema 4D R12 Demo folder, by selecting it, and in the Get Info dialog, change the permission to Read & Write, and then selecting "Apply to enclosed items..." from the popup menu at the bottom of the info dialog.
            Adios
            Cactus Dan
              On 04/09/2010 at 19:20, xxxxxxxx wrote:
              Down with permissions! :zipper_mouth:
                On 06/09/2010 at 01:35, xxxxxxxx wrote:
                Yeah, I also had this, some months ago 😉
                Permissions, of course.
                  On 06/09/2010 at 09:12, xxxxxxxx wrote:
                  We'll fix this with one of the next online updates.
                  Right now on the Mac permissions for the folders 'api_lib' and 'cinema4dsdk' need to be manually corrected.
