    Adding a point to an edge
    5 Posts 0 Posters 454 Views
      On 02/09/2010 at 19:48, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      Hey everyone.  I have been looking around and trying to figure this out.  I am guessing that I need to use the Modeling class for this.  Can someone point me toward how to add a point to the edge of an existing polygon object?   for example,  I would like to iterate through all points and add a point a certain distance away from each point.  Would I use SetEdgePoint()?   If not what would I use?
      Thanks.
      ~Shawn
        On 02/09/2010 at 20:18, xxxxxxxx wrote:
        If it causes the polygon to go beyond a quadrilateral then you will need to look at the Ngon routines because you can't have a CPolygon with more than 4 vertices (a,b,c,d).  It will need to be an Ngon otherwise.
          On 03/09/2010 at 01:07, xxxxxxxx wrote:
          Please have a look at the edgecuttool.cpp example, specifically the Modeling::SplitEdge and Modeling::SetEdgePoint methods.
          Btw. the Modeling library takes care of the Ngon stuff, so no need to worry about that.
            On 12/09/2010 at 16:08, xxxxxxxx wrote:
            okay so I am trying to cut an edge using the edgecuttool.cpp example..
            Am I doing this right?
             Real width = data.GetReal(MY_WIDTH);
            Modeling * mod = Modeling::Alloc();
            if (!mod->InitObject(op)) return FALSE;
                  for (int i=0; i < lngPolygonCount; i++)
                      mod->SplitEdge(op, i, oldPoint, width);
                      oldPoint = i;
            I am not getting any splitting at all happening on my cube.   Anyone know if I am leaving something important out?
              On 12/09/2010 at 16:35, xxxxxxxx wrote:
              Okay here's an update..  I'm sifting through the SDK and trying to match what it says to do...
              if(vpPoint)
                            AutoAlloc<Modeling> mod;
                            if (!mod || !mod->InitObject(op)) return FALSE;
                            LONG my1, my2;
                            Real width = data.GetReal(CHAMFER_WIDTH);
                                my1 = i;
                                my2 = i-1;
                                mod->SplitEdge(op, my1, my2, width);
                                oldPoint = i;
                                if (!mod->Commit()) return FALSE;
              still no dice..  trying to put this in the mouse input  method of a tool plugin
