    PrimSpline->GetSplineObject()?
    14 Posts 0 Posters 1.1k Views
      On 01/09/2010 at 19:55, xxxxxxxx wrote:
      Cinema 4D Version:   R12 DEMO
      I've managed to get the new(SplineLengthData) to work on editable spline (Point object)
      Before I used op->GetSplineObject() to calculate a position along a primitive spline (Circle, Arc etc.)
      But now "GetSplineObject()" is not recognized and I can't for the life of me
      find out how the get the LineObject out of a PrimSpline.
      Lennart
        On 02/09/2010 at 07:22, xxxxxxxx wrote:
        Any kindly hints?
        I'm going round in circles but hopefully missing something very obvious..
        Lennart
          On 02/09/2010 at 08:04, xxxxxxxx wrote:
          There is an example in the R12 COFFEE docs. You can directly pass the spline primitive BaseObject to the SplineLengthData::Init() method.
          little example:
          var op = doc->GetActiveObject();
          var sld = new(SplineLengthData);
          sld->Init(op,0);
          println(sld->UniformToNatural(0.4));
          println(sld->GetLength());
          println(sld->GetSegmentLength(3,4));
          sld->Free();
            On 02/09/2010 at 08:11, xxxxxxxx wrote:
            Ouch, that hurted... 🙂
            To much to play with and to little sleep 🙂
            Thanks Matthias
              On 02/09/2010 at 09:03, xxxxxxxx wrote:
              No, no, wait….
              As I wrote in the first post, I already use that to get the float
              -along- the spline.
              I need to get the position in space, the vector.
              It works for editable splines, as before, using op->GetSplinePoint(float,0))
              It doesn't work with Primitive Splines (Circle, arc etc…)
              In R11 I get the real spline by op->GetSplineObject().
              In Python I can use GetRealSpline().
              So what I don't get is, how can I get the RealSpline behind a Primitive spline in R12?
              It differs from before and I'm not able to find the solution in the SDK.
              Lennart
                On 03/09/2010 at 01:18, xxxxxxxx wrote:
                Oh, I see. Looks like this was removed with R12. I have to ask the developers if there is a replacement.
                  On 03/09/2010 at 06:20, xxxxxxxx wrote:
                  oh,oh, please let us know if it is actually removed!
                  Makes a big difference (slowing down expressions doing Make Editable ghosting)
                  Keeps my fingers crossed...
                  Lennart
                    On 06/09/2010 at 09:22, xxxxxxxx wrote:
                    I cannot confirm this - in R12 the following code works with parametric splines without a problem? Can you please specify what exactly doesn't work?
                    sld->Init(op,0);
                    sld->Free();
                      On 06/09/2010 at 11:12, xxxxxxxx wrote:
                      Hi Philip.
                      That is the same answer I got from Matthias but the problem remains for me.
                      I need to get the position -in space- as a -vector-.
                      I simply can not see how the example would give
                      anything but the float along a spline.
                      This works for a editable spline, a point object, using:
                      var vectorpos = op->GetSplinePoint(0.4,0);
                      But as I wrote it does not work as before with Primitive Splines
                      like Arc, Circle Flower Object etc.
                      What I did in R11 was to use the now as it looks defunct function :
                      var prim = op->GetSplineObject();
                      var vectorpos = prim->GetSplinePoint(0.4,0);
                      I'm afraid I cannot explain myself more clear without repeating myself.
                      I really hope I misunderstand something here but I haven't got to a solution
                      over the last two days and this is starting to get a burning issue for many of
                      my tools until I can get it all over to Python.
                      Please let me know what's up
                      Lennart
                        On 06/09/2010 at 11:25, xxxxxxxx wrote:
                        You're right - for point access the member function is necessary.
                        I've added the method GetRealSpline() for the next service update.
                        One difference will be that GetRealSpline does not return a copy of the spline (like GetSplineObject), but the original. It will be identical to the Python/C++ versions.
                          On 06/09/2010 at 11:59, xxxxxxxx wrote:
                          Thank you, thank you, thank you!!!
                          Lennart
                            On 29/09/2010 at 13:14, xxxxxxxx wrote:
                            I know no dates can be given, but are we looking at sort of close service update?
                            Or could it be a month away?
                            Lennart
                              On 30/09/2010 at 06:59, xxxxxxxx wrote:
                              Sorry, I can't give any dates or estimates when the update will be avaible.
                                On 27/10/2010 at 13:33, xxxxxxxx wrote:
                                Again, many, many thanks! Works a treat!
                                Lennart
