    ViewportHUD
    4 Posts 0 Posters 318 Views
      On 02/08/2010 at 02:22, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      does anybody know how to use the ViewportHUD class? I couldn't find any info at all.
      What i want to do is to draw a string in the viewport during the mouse loop of a tool plugin - exactly like the move/scale/rotate tools do it.
      I tried the following:
      // in MouseInput
      viewportHud = ViewportHUD::Alloc()
      viewportHud->BeginGroup();
      ViewportHUDControl* ctrl = viewportHud->AddControl(HUDCONTROL_TYPE_STATIC, doc, bd, NULL, DescID(10000), BaseContainer(), GeData("Hallo!"), DA_STRING);
      ctrl->SetTopLeft(500, 500);
      viewportHud->EndGroup();
      // in Draw
      viewportHud->DrawHUD(doc, NULL, doc->GetFps(), bd, HUDCONTROL_DFLAGS_NAME | HUDCONTROL_DFLAGS_FRAME);
      this code draws nothing, and DrawHUD returns False 😞
        On 02/08/2010 at 05:37, xxxxxxxx wrote:
        Hi Michael,
        I think it´s not working. At least I never got it working and if I remember correctly someone (guess it was Mikael back then) told me that it´s not possible to draw custom elements in the c4d HUD. Although I am not sure if that still applies but as it´s not working for you either it seems to be still valid.
        Instead use a GeClipMap and draw into it, then let it be drawn with DrawTexture instead. That works fine for me and I use it in my tree tool too, so that works for sure.
        HTH
          On 02/08/2010 at 05:56, xxxxxxxx wrote:
          Thanks for the info at least 😉
          I think i will use the workaround with the GeClipMap then.
          best regards,
          Michael
            On 04/08/2010 at 03:52, xxxxxxxx wrote:
            The classes and functions within lib_viewport.h are currently private and not meant for plugin development.
