    Deformed Objects
    4 Posts 0 Posters 340 Views
      On 28/07/2010 at 05:01, xxxxxxxx wrote:
      Cinema 4D Version:   R11.5
      Platform:   Windows  ; Mac  ;
      Hi, how can I find out if an object is being affected by a deformer or not.
        On 28/07/2010 at 08:27, xxxxxxxx wrote:
        Check this out:
        BaseObject* BaseObject::GetDeformCache();
        I'd say if it's not NULL, there has been some deformation going on 😉
        Jack
          On 28/07/2010 at 08:49, xxxxxxxx wrote:
          While that is correct, GetDeformCache() may return NULL for other reasons (and the object in question still be affected by a deformer) such as cache not yet built.
          A better approach might be to see if the object's children are deformers as an additional test:
          Bool deformed = (obj->GetDeformCache() != NULL);
          if (!deformed)
            LONG info;
            for (BaseObject* child = obj->GetDown(); child; child = child->GetNext())
                info = child->GetInfo();
                if (child->GetDeformMode() && ((info == OBJECT_MODIFIER) || (info == OBJECT_HIERARCHYMODIFIER)))
                    deformed = TRUE;
                    break;
            On 28/07/2010 at 09:30, xxxxxxxx wrote:
            Thanks all. The only problem with checking for deformers as children is that a deformer can affect it's parent object and the hierarchy below that parent, which means I will have to traverse the whole hierarchy from the top level parent, which I was trying to avoid.
                   JDP
