    LayerShaderLayer safe to "kill"?
    7 Posts 0 Posters 528 Views
      On 13/07/2010 at 11:08, xxxxxxxx wrote:
      Cinema 4D Version:   R11
      hi.
      the LayerShaderLayer parameter LAYER_S_PARAM_SHADER_LINK is "read-only" which is too bad really. nevertheless i can delete a BaseLink by setting the parameter like this:
      layer- >SetParameter(LAYER_S_PARAM_SHADER_LINK, NULL);
      this is dirty, filthy, bad style, i know, but can it cause problems?^^
      the result is, the BaseLink is deleted and in place of the deleted layer there is now an empty folder.
      i could live with this rather than totally discard my little plugin, as there seems to be no way to modify textures and shaders in a layer shader.
        On 16/07/2010 at 17:12, xxxxxxxx wrote:
        Maybe copy the contents from one layer, modify it as you wish, then insert it as a new layer and delete the old one? Just a quick guess.
        Jack
          On 17/07/2010 at 03:35, xxxxxxxx wrote:
          hmm, i want to replace and or delete layers and i guess modifying them will keep being the problem, for the only function i need is setting the link, which is read-only.
            On 17/07/2010 at 04:47, xxxxxxxx wrote:
            that's what I mean. Create a new layer with a new link, delete the old one.
            Jack
              On 18/07/2010 at 22:16, xxxxxxxx wrote:
              i don't think this is possible, as seen here:
              https://developers.maxon.net/forum/topic/4557/4340_insert-shader-under-layershader
                On 19/07/2010 at 01:13, xxxxxxxx wrote:
                At best it shouldn't crash Cinema but use it at your own risk.
                  On 29/07/2010 at 03:35, xxxxxxxx wrote:
                  thanks for your replies. i have to live with this then and will do some more testing to see if it causes problems.
