    SceneHooks and AM modes
    8 Posts 0 Posters 829 Views
      On 05/07/2010 at 19:58, xxxxxxxx wrote:
      Cinema 4D Version:   11
      Platform:      Mac OSX  ;
      Hey all,
      I'm building a combo plugin that includes an object, a tag, and a scenehook.  There are some global settings associated with the scenehook that I want to be available for the user to alter if necessary.
      So, I was wondering how I could get AM parameters for the hook, but it's not something that's "selectable" like an object or a tag so there's no way to display it in the AM.  Then there's a dialog, but I don't feel like going that route.  Then I remembered the new document mode in the AM in R11.5 and wondered if I could create my own mode and tie it to my hook.
      A quick look through the sdk, and I find lib_activeobjectmanager.  Woohoo, it looks like I can create my own AM mode, and it's available all the way back to R10, perfect:D  But it seems like it's a bit of a different beast than most of the other stuff I've seen in the SDK, so I thought I'd ask a couple of questions before diving in:)
      1.It looks like a class, but it's categorized as a "global", so is there any special way to deal with it? (ducks for cover in case that's a stupid noob question).
      2. It almost seems like it's designed for scenehooks... Like, it is the quintessential answer to my overall problem of adding parameters to a scenehook plugin.  Is that correct?  The function to register a new mode has a variable for a MESSAGEHOOK *hook, is that where I put my scenehook plugin to tie that mode to my scenehook?  And if so, how do I handle the description resource in this case?
      thanks!
      -kvb
        On 07/07/2010 at 03:03, xxxxxxxx wrote:
        Since R11.5 you can set the PLUGINFLAG_SCENEHOOK_SUPPORT_DOCUMENT_DESCRIPTION flag when you register the scene hook. This will cause the scene hook to appear in the document settings, just like the MoDynamics global settings for instance.
        Here is a simple example:
        #include "c4d.h"
        #include "c4d_symbols.h"
        #include "smyscenehook.h"
        class MySceneHook : public SceneHookData
              static NodeData *Alloc(void) { return gNew MySceneHook; }
        #define ID_MYSCENEHOOK 1025181
        Bool RegisterMySceneHook(void)
          return RegisterSceneHookPlugin(ID_MYSCENEHOOK,GeLoadString(IDS_MYSCENEHOOK),PLUGINFLAG_SCENEHOOK_SUPPORT_DOCUMENT_DESCRIPTION,MySceneHook::Alloc,EXECUTION_EXPRESSION,0,NULL);
        You can use standard description resource files, just remember to register the scene hook's description files.
        Bool PluginMessage(LONG id, void *data)
          switch (id)
              case C4DPL_INIT_SYS:
                  if (!resource.Init()) return FALSE; // don't start plugin without resource
                  if (!RegisterDescription(ID_MYSCENEHOOK, "Smyscenehook", NULL)) return FALSE;
          On 07/07/2010 at 12:20, xxxxxxxx wrote:
          Thanks Matthias,
          But what about all the pre-R11.5 versions of my plugin?  I need a solution that will work for R10+.  Does that mean I can't create my own AM mode for use with my plugin in pre-11.5 versions of c4d?
          thanks,
          kvb
            On 08/07/2010 at 02:48, xxxxxxxx wrote:
            If you want to create a new AM mode you have to register it first. The best place to do this is probably C4DPL_STARTACTIVITY because all plugins have been already registered at this point. You have to pass a function pointer for a message hook to ActiveObjectManager_RegisterMode(). In this message hook you can pass the scene hook over to the AM.
            Here is some sample code for the AM mode registration, this goes into the main.cpp.
            #define ID_SCENEHOOKMODE 1025002
            GeData SceneHookMessageHook(const BaseContainer &msg, void *data)
              switch (msg.GetId())
                  case AOM_MSG_ISENABLED:
                  case AOM_MSG_GETATOMLIST:
                      BaseDocument *doc = GetActiveDocument(); if (!doc) break;
                      PluginSceneHook *sh = doc->FindSceneHook(ID_MYSCENEHOOK); if (!sh) break;
                      ((AtomArray* )data)->Append(sh);
                  break;
              return FALSE;
              switch (id)
                  case C4DPL_STARTACTIVITY:
                      if (!ActiveObjectManager_RegisterMode((ACTIVEOBJECTMODE)ID_SCENEHOOKMODE, "Scene Hook", SceneHookMessageHook)) return FALSE;
              return FALSE;
            This should work from R10.x up to 11.5x.
              On 08/07/2010 at 19:45, xxxxxxxx wrote:
              thanks Matthias:D
              -kvb
                On 17/10/2010 at 20:39, xxxxxxxx wrote:
                If I may, I have a follow-up question regarding this:
                How do I then give this new AM mode an icon?
                thanks,
                kvb
                  On 18/10/2010 at 02:55, xxxxxxxx wrote:
                  You can change the icon by waiting for the MSG_GETCUSTOMICON message. Fill the passed GetCustomIconData structure with your own icon.
                    On 18/10/2010 at 05:35, xxxxxxxx wrote:
                    Thanks (yet again) Matthias:)  Working perfectly:)
                    btw... you should have a donate button on your site... I just went to go click it if it existed... but it didn't:(
                    -kvb
