    icon doesnt show up
    16 Posts 0 Posters 1.5k Views
      On 30/06/2010 at 02:09, xxxxxxxx wrote:
      Without any more info I can only guess. What does the arrow icon look like (screenshot)? Maybe you have an plugin ID collision. Are you using MSG_GETCUSTOMICON to display custom icons? Please post the code of the plugin registration.
        On 30/06/2010 at 02:25, xxxxxxxx wrote:
        this is the code:
        Bool Register_orgaLine(void)
         GePrint("- orgaLine");
         return RegisterObjectPlugin(pluginID,pluginName,OBJECT_GENERATOR|OBJECT_INPUT,orgaLine::Alloc,"OorgaLine","orgaLine.tif",0);
        and here is how it looks (top r11.5, bottom r11) :
        Ello
        btw, pluginID is from PluginCafe
          On 01/07/2010 at 05:58, xxxxxxxx wrote:
          Hm, sorry, I have no idea what could cause this. The arrow icon is unknown to me.
            On 01/07/2010 at 07:54, xxxxxxxx wrote:
            Maybe there is another plugin that registers the icon beforehand with the same id? try to temporarily remove all other plugins you have installed in r11.5.
              On 01/07/2010 at 12:41, xxxxxxxx wrote:
              thanks for your input. there is no other plugin in the folder. i am using the demo, but it also happens to my betatester. i probably can live with it, but i'd still like to know why this is happening.
              Ello
                On 01/07/2010 at 13:18, xxxxxxxx wrote:
                I've had something similar.
                Check if you're returning FALSE in PluginMessage (main.cpp).
                Jack
                  On 01/07/2010 at 13:21, xxxxxxxx wrote:
                  Oh wait, I read too fast.
                  My problem was that the icon didn't show up at all. Automatic icon replacement never happened to me 🙂 Sorry.
                  Cheers again.
                    On 01/07/2010 at 13:30, xxxxxxxx wrote:
                    ye, it can only have to do with something changed in r11.5.. well
                    Ello
                      On 01/07/2010 at 15:23, xxxxxxxx wrote:
                      Could it be a problem with the icon bitmap itself? Have you tried another icon bitmap, maybe one of the example icons?
                        On 01/07/2010 at 21:11, xxxxxxxx wrote:
                        Sometimes I find that icons saved in tif format don't work if they were saved with certain settings.   Try opening the tif in photoshop or fireworks and toy with different settings.   Can't remember which one caused this to happen for me but when I resaved it with different settings it worked.
                        Hope that helps.
                        ~Shawn
                          On 02/07/2010 at 00:06, xxxxxxxx wrote:
                          yes, i tried all of the above. it seems not to have to do anything with the image itself.
                          very strange...
                          ello
                            On 13/07/2010 at 02:03, xxxxxxxx wrote:
                            Hi, i got the information and could confirm it that it is an icon from the visual selector (create a new hot spot and click onto the question mark)...
                            what now?
                            Ello
                              On 13/07/2010 at 03:53, xxxxxxxx wrote:
                              Without seeing the code it's hard to say. Can you reduce the code to a simple plugin project which still shows the problem? You can send it over to sdk_support(at)maxon.net.
                                On 13/07/2010 at 04:23, xxxxxxxx wrote:
                                which code do you need? only the plugin.cpp or do you need other files, too?
                                  On 13/07/2010 at 05:40, xxxxxxxx wrote:
                                  If possible the whole project including resources. Please simplify the code as much as possible.
