    Extrude NURBS
    2 Posts 0 Posters 223 Views
      On 22/06/2010 at 07:53, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      i like to generate an extrude NURB in my own object plugin.
      BaseObject* CStaticTextClass::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh)
        BaseObject *main=NULL;
      // group all further objects with this null object
        main = BaseObject::Alloc(Oextrude);
      the plugin registration is
      return RegisterObjectPlugin(PID_STATICTEXT, name, OBJECT_MODIFIER,....
      Ok, i will get an object in the object manager. But if i moved an text spline under, i don't get the same behaviour like the standard Extrude NURBS object. I don't get the 3rd dimension.
      WHY??
      regards
      Markus
        On 22/06/2010 at 08:47, xxxxxxxx wrote:
        That's because the spline object has to be a child object of the ExtrudeNURBS (as usual), which isn't the case if it's a child object of your generator.
        Create a clone of the spline object and insert it as a child object under the ExtrudeNURBS object.
