    C4D FBX import 2011
    3 Posts 0 Posters 798 Views
      On 22/06/2010 at 02:27, xxxxxxxx wrote:
      Cinema 4D Version:   11.530
      Language(s) :
      Hi.
      Can anyone please answer me if there is an update coming for importing FBX 2011 for C4D? Probably coming with C4D v.12, but we need a solution asap.
      Because when I import an FBX file (exported from Revit 2011), only the model shows (grey), no materials, no lights etc.
      The new fbx format is based on mentalray protein 2.0 (fbx 2010 had protein 1.0), and our workflow from revit to cinema doesn't work anymore because of that.
      Thank you Autodesk!! Should have chosen ArchiCAD instead....  !Smile[URL-REMOVED]
      Thanks for any kind of response about
      /gaas
        On 22/06/2010 at 02:30, xxxxxxxx wrote:
        I believe i posted this in the wrong category....!Confused[URL-REMOVED]
          On 14/10/2010 at 03:17, xxxxxxxx wrote:
          hello,
          did you find answer to your fbx to cinema 4d import issue?
          I am just dealing with the same stuff...
          thanx
          martin
