    The perpendicular plane to a spline
    17 Posts 0 Posters 2.2k Views
      On 06/06/2010 at 09:49, xxxxxxxx wrote:
      So, I believe that, for what I'm trying to create, I just need to know the code to do this:
      I have been trying to get that information from the net but can't seem to find anything 😞
      So, I have a spline. I have access to the coordinates of any point along that spline. I also have access to the tangent vector of any point along that spline. What is the method to calculate the helix points around that spline?!? Anyone knows or could point me in the right direction?
      Rui Batista
        On 06/06/2010 at 10:49, xxxxxxxx wrote:
        Would this help?
        http://en.wikipedia.org/wiki/Helix
        This at least provides some formulas.
          On 06/06/2010 at 10:53, xxxxxxxx wrote:
          I had already been there, emberintherain. And, unfortunately, it doesn't help me much. I know how to create an helix along a line. Not along an arbitrary spline 😞
            On 06/06/2010 at 11:12, xxxxxxxx wrote:
            My theoretical go at it would be to describe a regular circle (local sin x , cos y) around the
            z direction ( of a matrix at spline position).
            Iterating the position of that matrix along the spline while
            calculating the circle would then describe a helix along the spline.
            (The movement along the spline corresponding to the "t" in that Helix formula)
            Lennart
              On 06/06/2010 at 15:47, xxxxxxxx wrote:
              That sounds logic and I can see it in my mind.
              The problem is how to make sure the "circle" gets mapped perpendicularly to the points along the spline.
              The matrix of the spline gives me just that, the matrix of the position/rotation/scale of the spline object, not the matrix of the points along the spline.
              Rui Batista
                On 06/06/2010 at 16:18, xxxxxxxx wrote:
                You need to build a matrix. The position is given by the spline point position.
                The rotation you build from the spline point position and the tangent position.
                The GetSplineTangent(x,0) returns a position in space tangential to the
                spline point position at distance x. (It doesn't give a angle).
                Using VectorToHPB(splinepoint - tangentpoint) will give you the
                basic rotation (skipping up vector to start with)
                So you basically build a AlignToSpline function moving a tangential
                matrix (instead of an object).
                This matrix is what you have as a base for the circle calculation.
                Lennart
                  On 06/06/2010 at 16:35, xxxxxxxx wrote:
                  Mmmmm, ok, I will give it a try. Thank you Lennart.
                  Rui Batista
                    On 06/06/2010 at 18:35, xxxxxxxx wrote:
                    So, this is a snippet of my code:
                    x=spline1->UniformToNatural(float(f)/(n_points-1));
                    pos=spline1->GetSplinePoint(x,0);
                    tang=spline1->GetSplineTangent(x,0);
                    r1=50*sin(31.415*f); // just for testing
                    r2=50*cos(31.415*f); // just for testing
                    hpb=VectorToHPB(vnorm(pos-tang));
                    new_mat = new(Matrix);
                    new_mat->SetV0(pos);
                    new_mat->SetRotHPB(hpb);
                    vec = vector(r1,r2, 0.0);
                    new_vec = new_mat->GetMulP(vec);
                    Should this be it? Its not working as I expected 😞
                    Rui Batista
                      On 06/06/2010 at 19:00, xxxxxxxx wrote:
                      See if this rude set up might help.
                      // Put COFFEE Tag on an object to circle the spline
                      // Add a point spline in link field.
                      GetFirstTag(obj,type)
                      var tag = obj->GetFirstTag();
                      while (tag){
                      if (tag->GetType() == type) return tag;
                      tag = tag->GetNext();
                      return NULL;
                      main(doc,op)
                      var ctag = GetFirstTag(op,Tcoffeeexpression);
                      var udpos = ctag#ID_USERDATA:1;
                      var spline = ctag#ID_USERDATA:2;
                          spline->InitLength(0);
                      var spos = spline->GetSplinePoint(spline->UniformToNatural(udpos),0);
                      var tpos = spline->GetSplineTangent(spline->UniformToNatural(udpos),0);
                      var srot = VectorToHPB(tpos);
                      var revs = 20; // revs along spline
                      var mym = new(Matrix);
                          mym->SetRotHPB(srot+vector(0,0,udpos*2*PI*revs));
                          mym->SetV0(spos);
                          mym = spline->GetMg()->GetMulM(mym);
                      op->SetMg(mym);
                      R11.5 example scene
                      Lennart
                        On 06/06/2010 at 19:41, xxxxxxxx wrote:
                        It helped me a lot but its still not working the way I want it to 😞
                        I want to adjust the points of a spline so that it spirals around another spline.
                        If its not asking you too much, could you take a look at what I have come up so far?
                        Pay no attention to the User Data parameters of the COFFEE tag. For now, only the Spline, Number of Points and Radius are working.
                        Thank you very much in advance.
                        Rui Batista
                        Spiral file
                          On 07/06/2010 at 08:10, xxxxxxxx wrote:
                          Hey guys. You must not add hpb rotations just like so 😜
                          Its better generate a local rotation matrix and multiply it to the right of the tangent plane matrix.
                          Here is a piece of code which works pretty well in Ruis scene:
                               var m_spiral = new(Matrix);
                               m_spiral->SetRotHPB(vector(0,0,t*2*PI*10));
                               var hpb=VectorToHPB(tang);
                               var new_mat = new(Matrix);
                               new_mat=new_mat->GetMulM(m_spiral);
                               new_mat=spline1->GetMg()->GetMulM(new_mat);
                               var vec = vector(0.0,radii,0.0);
                               var new_vec = new_mat->GetMulP(vec);
                            On 07/06/2010 at 13:51, xxxxxxxx wrote:
                            Thanks Michael, that shaved a few lines off in my set up.
                            Making a little Spiral Gadget here 🙂
                            Rui, did you get it working now?
                            Lennart
                              On 07/06/2010 at 18:40, xxxxxxxx wrote:
                              Yes, its working fine now. Well, I still have to add a few more options but the main part is already working.
                              Thank you all for the help 🙂
                              Rui Batista
