    dynamic_casts fail on OSX
    4 Posts 0 Posters 420 Views
      On 01/06/2010 at 05:53, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      Platform:      Mac OSX  ;
      we recently tried to compile our plugin using the C4D 11 SDK. On windows this worked without problems, on OSX though there are strange things happening now:
      I was able to compile and link everything without problems, when opening the plugin in C4D though, the program crashed. C4D crash report told me that a dynamic_cast failed. I checked the XCODE project settings and found out that "Enable C++ runtime type information" was disabled. I enabled this and recompiled - now linking fails, giving error messages like:
      "typeinfo fo GeModalDialog", referenced from:
      typeinfo for AboutDialog MainDialog.o
      symbol(s) not found
      Am I doing something completely wrong here? The code used to compile using 10.5 SDK without problems before...
      Any ideas?
      Many thanks
      Markus
        On 01/06/2010 at 06:06, xxxxxxxx wrote:
        you really need to give more information about the classes involved and a little bit of code. Is the base class virtual? So is it really polymorphic?
          On 01/06/2010 at 14:53, xxxxxxxx wrote:
          Just a guess: This error looks as if the API library has not been recompiled with rtti enabled. (only the actual plugin library, so it fails to link with the non-rtti api lib)
            On 02/06/2010 at 01:46, xxxxxxxx wrote:
            many thanks for your answers 🙂
            Actually that was exactly what was happening (found that out yesterday but forgot to post an update here) :
            I was under the assumption that the build options for my project propagated to the embedded _api project - they didn't. I enabled rtti in the api project, recompiled, all is well now 😉
            Markus
