    Unique object ID
    11 Posts 0 Posters 1.2k Views
      On 31/05/2010 at 04:58, xxxxxxxx wrote:
      why do you need a unique ID? Use the baselinks instead, they are there to safely identify individual objects.
        On 31/05/2010 at 05:24, xxxxxxxx wrote:
        hello,
        i'm using the COLLADA export from cinema4d to generate some 3d datas.
        But COLLADA don't support the UserData from cinema of course.
        For this case, i create an own plugin to export this additional data in a separate file.
        Later i must merge this data and for this i need an unique reference to the objects.
        A name is not unique and can frequently appears.
        Or maybe you can show me how i get the same IDs like in the COLLADA export.
        e.g:
          <library_visual_scenes>
             <visual_scene id="ID3">
                 <node id="ID4" name="Cube">
        best regards
        Markus
          On 31/05/2010 at 05:31, xxxxxxxx wrote:
          the problem is that there is no id that is unique to an object (at least not publically accessible or I don´t know of it), in c4d you have the baselinks which are unique! So the best way to handle this is adding an own tag to the objects and assign a certain id to that tag which you can retrieve for im/export.
            On 31/05/2010 at 05:53, xxxxxxxx wrote:
            I suppose you could also store an unique ID in the object's container.
              On 31/05/2010 at 06:19, xxxxxxxx wrote:
              do you know if COLLADA would export this data?
                On 31/05/2010 at 06:39, xxxxxxxx wrote:
                Sorry, I only now realize what the problem is. I don't think this will work this way. Hm, have to do some researching myself.
                  On 31/05/2010 at 06:42, xxxxxxxx wrote:
                  Who developed the COLLADA export modul for Cinema4d?
                  Maxon itself?
                  regards
                  Markus
                    Who developed the COLLADA export modul for Cinema4d? Maxon itself?
                    I can't really talk about the developers but it's a MAXON product.
                      On 31/05/2010 at 07:13, xxxxxxxx wrote:
                      ok, thanks a lot.
                        On 01/06/2010 at 14:42, xxxxxxxx wrote:
                        You should give
                        C4DOS.Bl->GetMarkerEx(const_cast<BaseList2D*>(bl),&l1;,&l2;);
                        a try. It takes a pointer to a BaseList2D object and returns two ULONG integers (l1 and l2 here). From what i have seen so far these numbers together are an id which is unique for each object in a document. The number is incrementet each time a new object is created. The Function is not documented though. It's not even mentioned in the docs. So use it with care.
