    Read User Data
    7 Posts 0 Posters 600 Views
      On 27/05/2010 at 04:47, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      I try to read the user data from base objects with the BrowseGetNext(..) function.
      I get back the DescID and a basecontainer with the data.
      But now i don't know how i can access to this data. Which IDs should i using?
      I get only the name of the "User Data" with following function.
      while ( pUserData->BrowseGetNext(handle, &id, &data) )
        uid = id[1].id;
        uType = id[1].dtype;
        GeData att_name;
      att_name = data->GetData(1);
      But i need also the value of it and some furter informations like min and max values or so.
      Has anyone an idea?
        On 28/05/2010 at 01:44, xxxxxxxx wrote:
        ok, now i get the additional attibutes like min and max value with the BrowseContainer class.
        But i don't get the value of the user data. Only the information, that a DA_CUSTOMDATATYPE is delivered.
        BrowseContainer brw(data);
                      LONG lid = 0;
                      GeData *att = NULL;
        while (brw.GetNext(&lid, &att)) {...
        How can i read the data value ???
          On 28/05/2010 at 02:12, xxxxxxxx wrote:
          What kind of user data type do you want to access?
            On 28/05/2010 at 02:17, xxxxxxxx wrote:
            every type. I add the User data in the attribute manager and choosen one type from the list. (Boolean, Integer, Real...). And with a plugin i like to export this data into an external file.
            regards
            Markus
              On 28/05/2010 at 02:18, xxxxxxxx wrote:
              Maybe you can show me an example for a LONG value ?
                On 28/05/2010 at 03:30, xxxxxxxx wrote:
                every type...
                Ah, ok. That's actually quite simple.
                Here is an example how to determine the data type and value of the user data entries:
                Bool MenuTest::Execute(BaseDocument *doc)
                  BaseObject *op = doc->GetActiveObject();
                  if (!op) return FALSE;
                  DynamicDescription *dd = op->GetDynamicDescription();
                  if (!dd) return FALSE;
                  void *dhandle = dd->BrowseInit();
                  DescID id;
                  const BaseContainer *bc = NULL;
                  while (dd->BrowseGetNext(dhandle, &id, &bc))
                      GeData data;
                      if (op->GetParameter(id, data, 0))
                          //data contains the user data data; the data type of the user data
                          switch (data.GetType())
                              case DA_REAL:
                                  GePrint("Real: "+RealToString(data.GetReal()));
                                  break;
                              case DA_LONG:
                                  GePrint("LONG: "+LongToString(data.GetLong()));
                                  break;
                  dd->BrowseFree(dhandle);
                  On 28/05/2010 at 04:07, xxxxxxxx wrote:
                  oh i see,
                  thanks a lot... it works
