    Plane
    5 Posts 0 Posters 605 Views
      On 20/05/2010 at 09:30, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      so in math, the equation for a plane is  x + y + z = 0
      how do I represent this in the C4D api?
      is the result from CalcFaceNormal the same as this equation?
      ~Shawn
        On 21/05/2010 at 01:01, xxxxxxxx wrote:
        Hello you can represent a plane by a point in Space (vector) and a nother normalized vector (the normal of the plane).
        all the best
        Franz
          On 21/05/2010 at 04:47, xxxxxxxx wrote:
          A plane is defined in Cinema as a plane through the planes global matrix.
          The orientation parameter of the plane (+/-x, y, or z respectively) defines how the plane is oriented in this matrix.
          While a plane mathematically could be defined by a point and a normal only as Franz suggested, this leaves the orientation of the other two matrix vectors undefined.
          So, to construct a plane, you need to construct an orthogonal matrix with the offset vector off [= any point on the plane], the normal vector and two new vectors for v1-v3. V1-v3 should be perpendicular to each other = orthogonal.
          Depending which of v1-v3 carries your normal vector, set the orientation parameter of plane accordingly.
          Hope it helps
          Kabe
            On 21/05/2010 at 05:06, xxxxxxxx wrote:
            right.... i loose this part, sorry 🙂
            to buil the matrix you can start by definig 3 point plane and use this tree point to obtain v1 and v3 with cross vector
            all the best
            Frabz
              all the best
              Franz
              Yes, this is the defintion of an infinite plane.
