    issues with DLL and STL containers
    8 Posts 0 Posters 937 Views
      On 20/05/2010 at 01:46, xxxxxxxx wrote:
      Cinema 4D Version:   R11
      Hey everyone,
      my name is Heinrich Löwe, im working for Sehsucht GmbH in Hamburg. Me and a workmate(Martin Chatterjee) are working on a multi-platform-exchange format. For this reason we have written a DLL library which containes the basic functionality. It is imported in plugins for various applications and c4d is one of them.
      I don't want to bore anyone with more details and will get straight to the point: The DLL is exporting functions which modify references to STL containers. If i use these functions in a C4D plugin, it always leads to crashes. However, they work fine with a direct inlcude of the code or in different environments than c4d.
      I've boiled down the code to show you the main point:
      Parts of the DLL library which are responsible for the problems:
      // define a dll import/export macro
      #ifdef DLL_TEST_EXPORTS
         #define DLL_MACRO    __declspec(dllexport)
      #else
         #define DLL_MACRO    __declspec(dllimport)
      #endif
      // A representative structure exporting a stl container
      struct DLL_MACRO MyStruct {
           template class DLL_MACRO allocator<int>;
           template class DLL_MACRO vector<int, allocator<int> >;
           vector<int> vec;
      // Global function which modifies the given reference
      void DLL_MACRO GlobalFunction(vector<MyStruct> &vec;)
           // just do something with the input
           vec.resize(10);
      Now the usage of the exported function in the C4D plugin code:
      // code is executed during the c4d startup phase, while
      // registering the plugin.
      Bool Register_MyTestPlugin(void)
           // create some stl container, using the exported structure
           vector<MyStruct> *b = gNew vector<MyStruct>;
           // call exported function which modifies my stl container
           GlobalFunction(*b);
           // kill it, at this point the plugin crashes
           gDelete(b);
      While running that plugin in debug mode everything works, up to the point where the vector is deleted. I tracked it further down to a call to C4DOS.Ge->Free() in the overloaded delete operator in the file 'c4d_memory.cpp'.
      Thas is the point where i got stuck and i'm hoping for your assistance to solve the problem,
      Heinrich Löwe.
        On 26/05/2010 at 06:19, xxxxxxxx wrote:
        Which Cinema 4D version are you using? My test DLL with Cinema 4D R11.5 seems to work fine.
          On 27/05/2010 at 01:16, xxxxxxxx wrote:
          I'm using R11 64bit on a windows 7 machine.
            On 27/05/2010 at 03:04, xxxxxxxx wrote:
            Ok, I can confirm the crashing on Cinema R11. Afaik it is due to the overloading of new/delete by the Cinema 4D SDK. Since R11.5 this is not the case anymore, making it easier to link to DLLs/DYLIBs. I am not sure if there is a solution for R11. I will forward the issue to the developers maybe they know a solution of the problem.
              On 27/05/2010 at 05:14, xxxxxxxx wrote:
              Strange now it crashes under R11.5 too. I'll have to ask the developers what is going on.
                On 28/05/2010 at 09:53, xxxxxxxx wrote:
                I upgraded to R11.5, and the test plugin (together with the test DLL) works fine now.  But the real plugin still crashes with the following message:
                Unbehandelte Ausnahme bei 0x000007fefd6caa7d in CINEMA 4D 64 Bit.exe: Microsoft C++-Ausnahme: std::bad_alloc an Speicherposition 0x02c25740..
                  On 28/05/2010 at 13:54, xxxxxxxx wrote:
                  try & catch?  😉 What about a little bit of source code that triggered the crash?
                    On 29/05/2010 at 06:31, xxxxxxxx wrote:
                    Hello again,
                    i debugged the code this morning, made some changes and it seems to work fine. However, there is still one thing which leads to crashes: Whenever i pass a std::string to the dll, the plugin stops executing, but it does work fine when it's passed by reference.
                    This does not work:
                    // method declaration in the dll (parameter passed directly)
                    bool openFile(string sFullPath);
                    // call it from the plugin
                    std::string str("some filename in here");
                    if (reader.openFile(str)) {
                    /* the plugin crashes when the method openFile() returns to the caller an the
                     * local copy of the passed std::string is deleted.
                    This works:
                    // method declaration in the dll (parameter passed by reference)
                    bool openFile(string &sFullPath);
                    I 'solved' the problem by changing everything to 'call by reference' in the dll, but it doesn't feel good having some unexplainable error somewhere around.
                    Greetings,
                    Heinrich Löwe.
