    strange phong tag issue
    5 Posts 0 Posters 514 Views
      On 23/04/2010 at 12:58, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      i have two different plugins. in both i use BaseObject::Alloc(Osweep) to create a Sweep object. But in one i need to explicitely create a Phong Tag using sweep->MakeTag(Tphong); but in the other the phong tag is created automatically. why is this??
      i am creating the sweep object exactly the same way in both plugins..
      thanks and cheers,
      ello
        On 23/04/2010 at 16:30, xxxxxxxx wrote:
        Do you happen to call sweep->SetPhong() in the other one? Calling SetPhong() (to set a phong angle) will create a Phong Tag.
          On 24/04/2010 at 04:15, xxxxxxxx wrote:
          thanks for your reply
          no, i didnt. I even tried to use sweep->SetPhong(TRUE, TRUE, 0.0); to create a phong that looks like there is none, and i tried SetPhong(FALSE,TRUE,0.0) to remove the existing phong tag, nothing works..
          i need to check what else could cause it..
            On 26/04/2010 at 02:37, xxxxxxxx wrote:
            Please post some code showing the problem.
              On 26/04/2010 at 13:05, xxxxxxxx wrote:
              thanks. i got it working by placing the SetPhong instruction after the sweep has been inserted and not before.
              ello
