    Unicode Line Separator (U+2028) works only on Mac
    9 Posts 0 Posters 1.9k Views
      On 20/04/2010 at 07:39, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      Like the Mac version the Windows version should support the Unicode Line Separator (U+2028) for introducing linebreaks in resources like this:
      MY_ERRORDLG_MESSAGE "This works in Mac\u2028but not on Windows!";
        On 20/04/2010 at 10:01, xxxxxxxx wrote:
        Add vote ^^
          On 20/04/2010 at 10:49, xxxxxxxx wrote:
          have you tried \r\n or just \r ?
          Edit: oops, sorry, I thought it worked on win but not on mac but that´s the other way round actually. So scratch that.
            On 21/04/2010 at 02:24, xxxxxxxx wrote:
            As already pointed out in another thread, the only thing that AFAIK does currently work on a cross plattform way is to add a Windows-Style CRLF like this:
            and Windows, but boy is it fugly!";
            Kabe
              On 21/04/2010 at 06:03, xxxxxxxx wrote:
              I'll forward the issue.
                On 22/04/2010 at 07:40, xxxxxxxx wrote:
                For the time being, I see only one workaround:
                In the .str file, write:
                MY_ERRORDLG_MESSAGE     "This works on Mac#as well as on Windows!";
                In your code, do e.g.:
                String ErrMsg = GeLoadString(MY_ERRORDLG_MESSAGE, "\n");
                Jack
                  On 27/04/2010 at 03:24, xxxxxxxx wrote:
                  Actually Cactus Dan posted another workaround, which seems to work on both Mac & Windows:
                  Use "/u000d" for CR:
                  MY_ERRORDLG_MESSAGE     "This works on Mac/u000das well as on Windows!";
                    On 27/04/2010 at 13:02, xxxxxxxx wrote:
                    Please use the vertical bar sign "|" to seperate lines, for example "First Line|Second Line".
                      On 28/04/2010 at 01:13, xxxxxxxx wrote:
                      AAARRRGH, why is Maxon introducing another *non-standard* way to do this?
                      Maxon defined that Unicode should be used for signs outside the standard ASCII range. The vertical bar is a standard ASCII char in the 7-Bit range, which should not have such a side effect IMO!
                      I would consider this behavior as a bug.
                      Kabe
