    Remove control sum characters from SN after entry
    5 Posts 0 Posters 415 Views
      On 20/04/2010 at 07:34, xxxxxxxx wrote:
      Cinema 4D Version:   11
      Platform:    Mac  ;
      I've a Serial Handler derived from SNHookClass, which works fine so far.
      The only remaining issue is that I would like to strip out the "technical" part of the serial, very much in the same way Maxon does it when you paste your Cinema 4D Serial. Only the serial number should be in the dialog after the number has been accepted.
      How to do that?
      Kabe
        On 22/04/2010 at 03:40, xxxxxxxx wrote:
        Any ideas on this one?
          On 22/04/2010 at 03:51, xxxxxxxx wrote:
          Afaik this is not possible for plugins. Btw. why would you want to do this anyway, makes no sense to me, at least not for plugins?
            On 26/04/2010 at 00:53, xxxxxxxx wrote:
            For the very same reason that you do it in Cinema:
            Show S/N in the S/N dialog that can't simply be copied out of the dialog,
            but are still valid for support calls or for identifying a user.
            Kabe
              On 26/04/2010 at 02:58, xxxxxxxx wrote:
              Ah ok, fair enough.
              Unfortunatly it's not possible through the SNHookClass. You have to use an own dialog.
