    Add GI to render settings
    3 Posts 0 Posters 398 Views
      On 17/04/2010 at 08:20, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      Hi everyone,
      I'm probably missing something obvious here, but how do I add GI to the render settings? I thought that I could do PluginVideoPost::Alloc() then insert that into the active render data for the document. Of course, the Alloc() call wants the type of videopost as a parameter and I can't find that for GI in the SDK.
      Am I going about this the right way or is GI not treated as a videopost? In which case, how do you add GI?
      Many thanks,
      Steve
        On 19/04/2010 at 02:06, xxxxxxxx wrote:
        Yes, GI is allocated just like other videoposts.
        The ID is VPglobalillumination.
        Example:
        Bool MenuTest::Execute(BaseDocument *doc)
          RenderData *rdata = NULL;
          rdata = doc->GetActiveRenderData();
          if (!rdata) return FALSE;
          PluginVideoPost *pvp = NULL;
          pvp = PluginVideoPost::Alloc(VPglobalillumination);
          if (!pvp) return FALSE;
          doc->StartUndo();
          rdata->InsertVideoPost(pvp, NULL);
          doc->AddUndo(UNDO_NEW, pvp);
          doc->EndUndo();
          rdata->Message(MSG_UPDATE);
          EventAdd();
          On 19/04/2010 at 02:09, xxxxxxxx wrote:
          Excellent! Thank you very much indeed. Problem solved.
          Steve
