    Transform UVs with CallUVCommand
    3 Posts 0 Posters 386 Views
      On 13/04/2010 at 04:18, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      I am trying to Transform the UV-Coordinates I generated with the CallUVCommand Function (c4d_painter).
      This works fine but if I try to transform the UV-Coords it doesn't have any effect although the function returns TRUE..
      Here is the Code, I would be grateful for any help.
      TempUVHandle *handle = GetActiveUVSet(GetActiveDocument(), GETACTIVEUVSET_ALL);
      settings.SetBool(OPTIMALMAPPING_STRETCHTOFIT, FALSE);
           settings.SetReal(OPTIMALMAPPING_DISTORTION, Rad(50.0));
           settings.SetReal(OPTIMALMAPPING_SPACING, Rad(0.0));
           settings.SetBool(OPTIMALMAPPING_PROGRESSBAR, TRUE);
           settings.SetLong(OPTIMALMAPPING_RELAXCOUNT, 0);
      CallUVCommand(points, nPoints, polygons, nPolygons,
           uvwStructs, baseSelects[iSelection], pointSel, po,
           Muvpolygons, UVCOMMAND_OPTIMALMAPPING, settings);
      BaseContainer settings1;
      settings1.SetReal(UVCOMMAND_TRANSFORM_SCALE_X, 10.0);//scaleFactor);
      settings1.SetReal(UVCOMMAND_TRANSFORM_SCALE_Y, 11.0);
                Muvpolygons, UVCOMMAND_TRANSFORM, settings1);
      handle->SetUVW(uvwStructs);
        On 13/04/2010 at 06:38, xxxxxxxx wrote:
        I don't exactly know what is wrong with your code but the following test code works fine for me.
        Bool MenuTest::Execute(BaseDocument *doc)
          BaseObject *op = doc->GetActiveObject();
          if (!op || op->GetType() != Opolygon)
              return FALSE;
          BaseContainer settings, settings1;
          TempUVHandle *handle = NULL;
          handle = GetActiveUVSet(doc, GETACTIVEUVSET_ALL);
          if (!handle)
              goto Error;
          settings.SetBool(OPTIMALMAPPING_PRESERVEORIENTATION, FALSE);
          settings.SetReal(OPTIMALMAPPING_SPACING, 2.0);
          settings.SetLong(OPTIMALMAPPING_RELAXCOUNT, 1);
          if (!CallUVCommand(handle->GetPoint(), handle->GetPointCount(), handle->GetPoly(), handle->GetPolyCount(),
              handle->GetUVW(), handle->GetPolySel(), handle->GetUVPointSel(), handle->GetBaseObject(), handle->GetMode(),
              UVCOMMAND_OPTIMALMAPPING, settings))
              goto Error;
          handle->SetUVW(handle->GetUVW());
          settings1.SetReal(UVCOMMAND_TRANSFORM_MOVE_X, 0.0);
          settings1.SetReal(UVCOMMAND_TRANSFORM_MOVE_Y, 0.0);
          settings1.SetReal(UVCOMMAND_TRANSFORM_ANGLE, 0.0);
              UVCOMMAND_TRANSFORM, settings1))
              goto Error;
          FreeActiveUVSet(handle);
        Error:
          return FALSE;
          On 14/04/2010 at 02:14, xxxxxxxx wrote:
          Thanks a lot, got it working now 🙂
